Question about Honda Eu6500is Eu6500 Generator Service Repair Manual 61z2500e4
Generator starts then shuts off - Honda Eu6500is Eu6500 Generator Service Repair Manual 61z2500e4
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Honda generator
The running on choke is caused by a fuel restriction. Check the fuel flow from the tank to the carburetor.Change the fuel filter if it has one. If its good, then the restriction is in the carburetor. The generator is shutting down due to the low rpm coming from the engine. A carburetor rebuild may need to be done.
Oct 19, 2013 | Electrical Supplies
UNIT SHUTS DOWN FREQUENTLY
How soon after starting does it shut down?
The hour meter is fed directly from the AC output off the generator stator, if there is no AC output the meter will not run. Assuming it shutdowns quickly, check 1st the oil level and make sure the low oil sender unit is ok, wire #24 to ground. If that is bad it will shut down. Check to see if you have 240V on L1 and L2 on the breaker for the brief time it does start, that will confirm stator/rotor has an output, then your problem moves from the generator portion to either the oil sender, or control board.
Feb 24, 2013 | Powermate Coleman Standby Generator...
Coleman Powermate PM0545007 generator. Unit started and ran. I turned on a window air unit and it worked ok then in about a minute the generator shut off. We are in a hurricane, so I'm trying to...
The generator has a low oil level sensor. Fill the oil all the way to the FULL mark and try it again.
IF you still have the problem after adding oil; repsond here and I can still help you. Just want to get this off as it has been 4 hours since your post.
Kelly
Aug 28, 2011 | Coleman Powermate Premium Plus 6250W...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be corrected?
May 28, 2011 | Kohler 12 kW Emergency Power System -...
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
Honda Eu6500is Eu6500 Generator Service Repair Manual 61z2500e4 Logo
54 people viewed this question
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
ray gallant
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
