Motherboard diagram KSWAA LA-4981P
Trying to locate BIOS chip on this mobo from a Toshiba L500 Any ideas Tia
  • 205 Answers
SOURCE: motherboard pc chips m810 lmr v7,1
The beep codes are not universal, but there are a few popular BIOS's and you can figure out what 2 beeps means if you can find your BIOS listed here:
http://www.computerhope.com/beep.htm
The name of your BIOS should appear on the monitor as you're booting.
Posted on Nov 20, 2007
  • 1027 Answers
SOURCE: K8S-LA mobo heat sink fell off.
That is the 'Northbridge' chip that provides the I/O interfacing for the main chip. The heat sink is normally held on with glue as you surmised, and should be re-done with a thermal conductive glue. The glue (a silver filled epoxy) is available from MCM electronics or from Mouser. Be sure to thoroughly clean the chip and heat sink before re-gluing.
Posted on Sep 01, 2008
  • 4 Answers
SOURCE: motherboard crash bios
1st remove ur mother board battery and clear cmos and press reset when machine start then shut down and change a new battery and fixd cmos. i hope ur problem will solv
Posted on Mar 17, 2009
Geekman
  • 32281 Answers
SOURCE: Bios ROM checksum error (Compaq SR5237CL with M2N68-LA MB)
A BIOS checksum error can be caused by a nearly flat BIOS battery.
I would replace the BIOS battery first before attempting to upgrading the BIOS.
Some motherboard BIOS firmware is upgraded by running a program that has been copy to a DOS boot disk or the upgrage maybe done from within the BIOS setup. These firmware upgrage and instructions are on the motherboard WEB site, in your case the Compaq/HP WEB site. Make sure you select the upgrade for your model motherboard.
NOTE it is possible that if you make a mistake you could ruin your motherboard, if you are not sure seek help from a computer savy friend.
Use this link :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Posted on Sep 17, 2009
SOURCE: I need a manual and diagram for my hannstar j mv-4...
reset cmos of hannstar j mv-4 motherboard
Posted on Aug 11, 2010
Need to locate CMOS jumper on Toshiba satellite L505-13J for BIOS reset
Does it have a battery? Removing for a few minutes seems to work, but keep in mind current BIOS setting might change.
Jul 19, 2012 | Toshiba Satellite L505-13J WXGA HD 15.6"...
I have a PNY MBM630I7150 mobo. I used to work with ASUS mobos (since 1987) and flashing the BIOS was easy. This current MOBO appears not have the option to flash (none can I find). How do I flash the...
There is no option to flash this motherboard's bios. PNY has not offered any BIOS updates and offers no way to alter the included BIOS. Sorry about that.
The manual is located here if you would like to reference it: http://www3.pny.com/support/media/Files/589b1671-0c6a-4367-b7e6-3ea8a83c560a/mcp7150_v1.PDF
May 06, 2011 | PNY MBM630i7150 Motherboard
Changed out the motherboard reformatted a blank hardrive, No issues in the reformat.Installed drivers then updated the bios.Currently will only boot to bios briefly then shuts down.Tried resetting the bios...
Sounds like your BIOS update did not complete successfully. Head to the board manufacturers website and check if there is some way you can reload the BIOS and recover from this. Most boards now have dual bios which means that if one bios chip fails or an update fails, you can reload the stored BIOS through the other chip. If you are unable to recover from a failed BIOS update, you may need to purchase a replacement BIOS chip from the board manufacturer. You may even be able to reload the original BIOS onto the chip through your local PC repair store so give them a call and enquire..
May 21, 2010 | HP Compaq Presario SR1300NX (PP195AA) PC...
I was given an L500. It powers but fails to POST, this happened after a recommended BIOS update. Any kind of debug ports or something to sort this out?
After a BIOS update, if it fails to post, the BIOS update got corrupted. This happens (rarely) and when it does, the only thing that can be done is to remove the BIOS chip and have it burned at a local repair shop (or sent into Toshiba for a replacement). Without the BIOS functioning properly, the computer can do nothing at all. If your BIOS is not on a removable chip, then the computer will have to be sent to Toshiba to have the BIOS replaced.
May 12, 2010 | Toshiba Satellite L500 Series Notebook
Mobo Compatibility and tech/spec variations
All Asus P5GC-MX/1333 mobos are "X-series" boards.
If you put higher speed ram on that mobo, it will just run the ram at lower speeds.
The board will not take 1333 speed DDR3, because it is only DDR2 compatible.
OVerclocking is complicated and risky, here is neither the place to teach or learn overclocking.
Some newer core 2 chips will automatically overclock, when all but 1 core is in hibernation (which will never happen if you are using vista). Other than that overclocking involves setting the bios to increase the memory buss speed, as well as slightly increasing the cpu and ram voltages as needed for stability. There is a great risk associated with manually overclocking and adjusting voltages, and should not be attempted by beginners on machines they value.
Dec 27, 2009 | ASUS P5GC-MX/1333 Motherboard
Serious issue with a proc upgrade for my Toshiba A65-S1062
just because a chip is supported does not mean that it wont need a bios update.
Mar 09, 2009 | Toshiba Satellite A65-S1062 Notebook
BIOS UPLOAD
Ah, that is a nasty problem. Sounds like the BIOS got corrupted. You have several options:
1. Get another bios chip from the mobo manufacturer.
2. Get another motherboard and use it to program your bad chip. See here how
3. Dump the old mobo and buy a new one.
I would go with option 3. The other options are just a big headache.
Dec 28, 2007 | EPoX EP-8HMMI-A Motherboard
Computers & Internet Logo
470 people viewed this question
David Payne
David Payne
