Question about Powermate 10 in. 43 cc Gas 2-Cycle Cultivator PCV43
Powermate cultivator recoil pullcord locked - Powermate 10 in. 43 cc Gas 2-Cycle Cultivator PCV43
2 Suggested Answers
  • 430 Answers
SOURCE: My powermate 43cc cultivator was working until a rock got lodged in it. It started up and then the engine shut off. Now it is difficult to pull the recoil and makes a clanking as you pull it. Feels li
IT is possible the flywheel key is sheared.
Posted on Oct 01, 2012
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
My powermate 43cc cultivator not getting gas through carb
Replace the fuel filter. Check float bowl valve in carburettor
Oct 22, 2013 | Powermate 10 in. 43 cc Gas 2-Cycle...
Homelite ohv 140cc
Remove recoil assembly. Observe cord installation. Remove old cord. New cord is sold by the foot at mower repair shop. Replace cord, reassemble recoil assembly.
Jun 18, 2013 | Garden
Want to remove the starter recoil from my powermate generator
I got one of these pieces of junk, and had same problem you described.
You will need to remove the end panel to get to the blower housing. You will have to thread the rope through the handle until you have enough slack to remove the rope from the handle. The end panel should now be free to remove entirely.
Find the 3 bolts that hold the blower housing on, and remove them. Once you get it off, make sure that the rope has a knot in it so it won't get retracted into the pulley recoil assembly. Take a screwdriver and push the rope back down into the pulley (that was my problem). Assembly is opposite of taking apart.
May 23, 2010 | Coleman Powermate Premium Plus 6250W...
Pull start recoil assembly
I bought a replacement recoil starter for my 1850 at Pats small engine parts. The part number for a 3.5 B & S is 499706. If you look on the heat shield on the side of the motor there is the engine model and s/n. Hope this helps.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Pull cord stuck
it sounds like the recoil spring in the "housing" is jammed( or something is broken) youll have to take this apart without breaking it. you may have internal engine damage if it was unusually hot and the pullcord jammed. try using a richer oil mixture for fuel also if you fix the pullcord. hope this helps, keep me posted.
Apr 18, 2009 | Mantis 2-Cycle Tiller
Husqvarna model 700DRT the rope pull is stuck
usually three/four bolts hold the recoil housing on the engine. two on top two on either side of bottom. let me know if im wrong i have other answers
Apr 08, 2009 | Mantis 2-Cycle Tiller
Coleman powermate 5000 gen.
I assume it is a hand start genset. The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clen the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Sep 17, 2008 | Coleman Powermate Powermate 5000W...
Powermate 10 in. 43 cc Gas 2-Cycle Cultivator PCV43 Logo
89 people viewed this question
Top Powermate Garden Experts
Dennis Key
Dennis Key
john h
Are you a Powermate Garden Expert? Answer questions, earn points and help others
