Question about Sony PVM-2541 25" OLED Monitor -
PVM 2541 is no starting and show the startclock for ever
Pvm 2530 turns reddish color soon after turned on
This might be a CRT base card fault. Replace the CRT connecting socket at this card. The fault technically called as 'one color predominant screen'. If you wish to get some more details about this kind of fault to CRT TVs, check this link. Pull up older posts there. One among these posts have detail descriptions.
Mar 14, 2013 | Televison & Video
How to connect mercury PVM 900 motherboard
you need manual here it is http://www.driverssoftwareupdates.com/p/pvm_900m_manual.html
Jan 15, 2013 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Hi this monitor dont turn on.and the one of fuses on main board was broke i want to send me electronic design of sony pvm-9l2/5 monitor. thanks a lot.
Try and replace the fuse that was found damaged. if the fuse blows out again there are errors in the main power supply whcih is the SMPS unit.
Check this link for some tips.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Jun 13, 2011 | Sony PVM-9L2 9 in. Portable Television
Pvm-14m4u: horz.deflection unstable, "flag
with cathode raid televisions this is common in older units. the screens deteriate overtime and eventually fail. honestly, i would recommend purchasing a new television. as repairs for crt televisions are costly as parts are not made anymore.
Mar 23, 2011 | Sony Televison & Video
I am not able to download drivers at mercury website. I get a message saying the file is not available on the server.
Try downloading the drivers for the motherboard MERCURY PVM 7 PRO
The chipsets and the audio IC are same as your motherboard so these drivers would perfectly work
here is a link for the PVM 7 Pro drivers
http://www.mercury-pc.com/downloads_list.php?productid=677
Feb 26, 2011 | Mercury P4VM800M7 Motherboard
Will mercury mother board (pvm7pro 1.0) supports graphic card
first you must check that *********** board has capacity to use 8x graphic card, if you had a spare 2x or 4x graphic card try on it.
send me reply
Dec 01, 2008 | Computers & Internet
Sony PVM-20M4U
These will run a bit hot, but make sure you have enough compound on it. If the old stuff was dry, use a solvent to remove it and replace the compound with plenty of new stuff.
Dan
Jun 06, 2008 | Televison & Video
No sound
you must change your microphone cabel with new  good brand.
Feb 24, 2008 | Peavey PVM 22 Microphone
Sony PVM-2541 25" OLED Monitor - Logo
27 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
