Question about Chicago Pneumatic Air Tools & Compressors
Chicago air compressor type - 2HN2-37/22P cooling water required
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: i cannot find parts for
What type of engine?
--W/D--
Posted on Mar 03, 2011
Torion ta14 unit where does the water go to fill
This is not Refrigerator This is Air Conditioner
you wrong category
This is the specs for you unit:
4.0kw Portable Air Conditioner (14,000btu)
Including Flexible Window Kit
Benefits:
• Suitable for any bedroom or small living
• No Installation Required
• Timer On/Off
• Remote Control
• 3 Speed Fan + Dehumidifier
• 3 Year Replacement Warranty
Specifications:
• Cooling Capacity: 4.0 Kw (Cooling Only)
• High Air Flow 570m3
• Plug Type: 10A
• Control Type: Manual Buttons or Fully Remote Control
R410A Gas
The last is the KEY. the unit don`t work with water works with GAS R410A
This is compressor type Portable Air Conditioner
Nov 29, 2017 | Refrigerators
What grade oil do I use to change out on my Chicago Pneumatic RPC-561VNS? The manual says a compressor grade non-deturgent oil should be used, but does no specify a grade.
Hi and welcome to FixYa, I am Kelly.
Compressor grade oils are basically SAE30 W oil. Read this:
Rol-Air OILCOMP30W34C Air Compressor Pump Oil - 30W Quart features ,
Specially engineered and tested to match the requirements of Rol-Air air
compressors , Provides superior rust and corrosion protection.
I.e SAE 30W oil / the same thing you would use in an older lawn mower engine or generator.
What they don't tell you is because they have re-labeled the 30W oil to OILCOMP30W they can charge you big time for SAE 30W oil. The only difference is the label.
Thanks for choosing FixYa,
Kelly
Sep 22, 2011 | Chicago Pneumatic 60Gallon TwoStage Air...
Compressor will run but not produce air
Check your safety valve is closed by pulling it out and releasing it. You can use a mixture of dishwashing soap and water to drip on the valve to see if it makes bubbles identifying a leak. Next make sure the petcock valve on the bottom of the tank is closed and not leaking by using the soapy water again. If you cannot close or fix the valve replace it. The next trouble shooting will require checking the air input to the tank but be careful since the tubes could be hot.
Aug 18, 2010 | Chicago Pneumatic Qrs 5 HP/3 Phase Rotary...
Looking for a product or instruction manual for a Mongomery Ward 2hp air compressor circa 1970's approx. Has the art.no. xer6468 and serial #12039-215993 printed on the side. This is a 2 cylinder oil...
If you need to tighten belt loosen the motor and slide back until belt taut and should have about 1/2" to 3/4" in deflection. You might try ebay for manual
Jul 29, 2017 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
What tpye of oil goes in the compressor
According to the Owner's Manual, 30 weight compressor oil is recommended. I'd use AMSOIL PCK, even though it's 40 weight. The pump will run cooler, last longer, use less gasoline, and require fewer oil changes. I'd also recommend AMSOIL's AFF 0W-40 Synthetic 4-Stroke Power Sports Oil for the motor for the same reasons.
Jul 16, 2010 | Chicago Pneumatic 30Gallon TwoStage Air...
WATER IN PNEUMATIC PRESS
compressors build up water u need a water separater and filter in line
Jun 28, 2009 | Chicago Pneumatic CP796 1" Extra Heavy...
Chicago forge horizontal air compressor will not build
Here are some simple tests that will help solve your problem. Check for leaks with soapy water on all the joints and the drain valve. With compressor running and it has reached all the pressure it can muster, remove the air filter and place your finger over the intake port, you should feel good suction and the compressor should speed-up if pump is working and pressure is leaking out. If you feel good suction then pressure could be leaking past cylinder/ring if it is oilless. Check upper part of cylinder for scratches or torn vinyl ring. If you do not feel suction, but rather air blowing out of intake then you may have bad reed vales or torn gasket in head. Another simple test is to run compressor for a few minutes and disconnect power then listen for air leaks at the pressure switch unloader valve. If leaking replace the in-tank check valve (brass valve). Follow the discharge airline to the tank, there you will find the checkvalve. Good Luck and email if you have questions.
May 03, 2009 | Chicago Forge AF4HH 15 - Gal. 4.0 - HP...
My verticle vt631402aj compressor motor boggs down before pressure can reach 15 lbs.
hi your problem sounds tp be associated with your nonreturn valve this is not sealing ,allowing pressure to flow back to your pump from your reciever/tank ,this is a"service part"and do require replacement periodically
hope this is of help ian
Dec 29, 2008 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
Open Questions:
Air Tools & Compressors Logo
32 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
