Question about Acer Aspire 5100 Notebook
Cracked lcd ok i have a cracked lcd screen on my acer 5515. what do i need to do so that i dont have to but another laptop or is that the best thing to do i havent even had it a full week yet
    Novelist:
  • 126 Answers
This is very simple sir if the lcd screen is broken before it damages some of the other parts of the computer u need to replace the lcd screen
Posted on Jan 26, 2009
I have an Acer Aspire 5515 laptop. My computer will turn on but it shows a black screen. I've tried turning it off and back on again. Removing the battery but it hasn't helped. Any suggestions??
Wow this is tuff,
Setting from keyboard, possibly.
Software, not likely.
Video Card, possibly.
LCD Screen, very likey.
But with no screen you options at home are limited.
There is a setting on laptops that allow you to send the video output to an overhead projector and cuts the laptop screen off. However, when you re-boot it usually defaults to the screen.
I betting on a screen failure. You may want to take it to a PC Repair shop. Or, buy one here,
http://www.hootoo.com/154-inchs-acer-aspire-5515-laptop-lcd-screen-panel-p-11162.html
http://www.amazon.com/ASPIRE-LAPTOP-SCREEN-SUBSTITUTE-REPLACEMENT/dp/B003XHDARC
Good Luck
Aug 12, 2011 | Acer Aspire 5500 5570-2609 Laptop
How do i find hotkeys on acer aspire 5515 laptop
The Hotkeys are;
1) Fn (Function Key) + F1 = Hotkey Help; Displays help on Hotkeys
To go on anyway;
2) Fn + F2 = launches Acer eSettings Management in Acer Empowering Technology.
3) Fn + F3 = Launches Acer ePower Management in Acer Empowering Technology.
4) Fn + F4 = Puts the computer in Sleep Mode
5) Fn + F5 = Toggle the laptop from it's monitor to an external monitor, or use both.
6) Fn + F6 = Screen Blank > Turns the Display Backlight off to save power. Press any key to return.
7) Fn + F7 = Touchpad toggle > Turns the internal Touchpad on and off.
8) Fn + F8 = Speaker toggle> Turns the speakers on and off
9) Fn + Right Hand Triangle > Brightens the LCD screen
10) Fn + Left Hand Triangle > Decreases the LCD screen brightness
Acer Aspire 5515 Service Manual ( Free)
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go down to the second Aspire heading.
The one that starts with Aspire 1200.
Drop down to line 6, then go across to the right, and click on 5515.
This is a PDF file. The computer you are on now has Adobe Reader on it, which uses PDF files.
I would suggest upgrading to Adobe Reader 9 (9.3.4.) though, if this isn't the version on the computer.
After you click you may not see anything happening for up to 30 seconds.
The file is downloading in the background.
Usually it takes a few seconds to see the first page, and additional time to fully download.
Suggest you let the file fully download before looking through it.
This is a SERVICE MANUAL, not a User Manual. Much more detailed, including disassembly procedures.
Nov 12, 2010 | Computers & Internet
Acer 5515 on external monitor
Get an VGA cable and connect your external monitor to your laptop via a VGA port that is usually used for digital projectors. In this VGA port, you can initiate dual monitors.
Then look at your keyboard and look an icon in your function keys (F1 to F12) that looks like a pair of an LCD and a TV like this {LCD icon/ TV icon}. In most laptop keyboards, this is located in F4.
When found, and with the external monitor hooked to the laptop via VGA port using a VGA cable, press and hold down the FN key and press the function key where the icons described above is located. Example, FN + F4 to toggle a single and a dual monitor.
Give it a try.
Jun 26, 2010 | Computers & Internet
I have an acer aspire 5515. After downloading a
hi
you have problem with you OS just reinstall OS it will solve the problem
Jun 04, 2010 | Acer Computers & Internet
Why does m acer aspire 5515 have a green line going down the left side of the screen?
the lcd is bad, and cannot be repaired but only replaced. manufacturers warranty is usually 1 year.
Nov 18, 2009 | Acer Aspire 5610-4648 Notebook
Acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info
Aug 14, 2009 | Acer Aspire 5610-4648 Notebook
I need to hook my Acer 5515 to a big screeen or a projector
most of the laptop nowdays have a vga port on them the projector can easily connect to thse laptops as it has a facility to do so
use the properties option to select the Projector screen as a 2 nd screen and open your presentation up on that screen
Jun 30, 2009 | Acer Extensa 5420-5687 Notebook
Acer 5515 backlight problem
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5100 Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
