Question about Jensen VM9510 Car DVD Player
Uv8 some seakers dont work in dvd/cd mode
Uv8 in dvd/cd mode the door and back speakers dont work but the tweeters do work in radio mode all speakers work fine it is a infinaty sound in a dodge truck
  • 116 Answers
You have the wrong wire hooked up to turn on your amplifire. You used the blue wire but need to use the Blue/White wire!! That is an amp turn on wire Thje blue one is for a power antenna and goes dead when you put in a disc. The tweeters play because they are hooked direct to your Jensen. You'll be jamming in no time.
Larry T
Winona Lae IN
Posted on Jan 28, 2009
I have a BMWx-309 Nitro Tweeters. Where do i wire? Front speakers on cd player,door speaker?
Assuming you do not have factory tweeters then either is acceptable. Use whichever is easier to get to...door speakers if mounting tweeters on door or cd player if mounting on dash.
Aug 04, 2016 | Cars & Trucks
Hello again. Sorry to say my knowledge is lil... I want to replace stock deck. Here is the stuff i want to put in it. Could you take a look and give an opinion if maybe i cant get away without putting a...
ok as for the deck just get the wiring harness for your car so you dont have to cut the old one out and that would eliminate the need for a wireing diagram with that done you should be able to hook all speakers you want to the stock spot so for a tweeter just hook it up with the door speaker there arnt any extra will only need a amp for a subwoofer unless you choose to put your mids and highs on one and if you didnt want to change your deck hook up the tweeters would be the same way hope this helped
Mar 30, 2010 | Car Audio & Video
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Front speakers
either the wires in the boot where door folds open has broken wires in it or the most likely case you have 2 blown wolfers and 1 blown tweeter. common for cars with the monsoon stereo system, they made the radio better than the speakers.
Mar 09, 2009 | 2001 Volkswagen Beetle
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
Nov 26, 2008 | Jensen VM9510 Car DVD Player
Adding new speakers to the deck
You need to know if these are Pizo tweeters or dome tweeters. If Pizo just hool them up to the white and gray wires off the kenwood. if not, then you should go to your local stereo shop and by bass blockers (small capacitors will do). this is only to "erase" the ohm load. once you have those inline of the POSITIVE wire you can hook the up to the gray and white wires. Good luck hit me back
Mar 03, 2008 | Kenwood KDC-135 CD Player
Jensen VM9510 Car DVD Player Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
