Question about Bosch Washing Machines
Hoover dynamic 8+ washer lock light keeps flashing and nothing happens it stopped working yesterday half way through a wash, managed to put a wash on this morning and now it has stopped working agai
Stopped half way through a wash yesterday, could not select any other programmes. Lock light just keeps flashing when start button is pressed as if it thinks the door is not locked. Have checked for kinks in pipes, made sure water is getting through and checked filter is clean.
SOURCE: Machine won't start and clicks if turned on with door open
Ok, this is the fix:
No payload. Close the door. Press off, then press on. Then enter a program starting by selecting the fabric and the others as usual. Do not press start, instead press the slip button to advance the programme to the very last phase, ie drain and empty. Then press start. It will perform this operation with no load and pump out the “no water”. This part takes 5 minutes. After the 5 mins the programme will end and the machine will beep annoyingly, but the computer will be reset and you can clear the program and use the machine as normal.
Why?
I had the same problem. The stupid computer inside remembers the program whilst it’s off and unplugged. What has happened is you accidently pressed start and start again to pause it in very quick succession. This confuses the computer and it thinks that a program is in progress. This is why it wants to close the door. There is no problem with the latch (unless it is a separate problem). You have to let it play out a program to reset it, which is why you can play the very last “drain” segment.
Question.
Presumably there’s a way to reset the computer either by a secret button combo or shorting out two pins from the computer box. I don’t know. If someone knows this please tell me.
Good Luck!
Posted on Nov 18, 2008
SOURCE: Door Lock LED flashing
The solution from testy helped me but I decided to change it.
I cut the plastic latch away from the end of the interlock,just the little bar that holds the door closed.This means that the lock position doesn't affect the door.
I then used the little piece of plastic to act as 2 packing pieces to hold the lock half closed. This works fine.
Don't push the lock fully closed or it doesn't work
Posted on Nov 29, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
SOURCE: Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
Posted on Jan 18, 2010
SOURCE: kenmore elite he3 - door lock
fdl error code on kenmore elite he4 washer. wont start after selecting wash cycle
Posted on May 02, 2010
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
My Indesit Moon 1400 has stopped working. Shortly after the cycle starts the blue LED lights at start and 40 deg flash rapidly. Washing inside machine is soaking wet but has neither washed nor spinned. ANy...
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Jan 30, 2010 | Indesit W 123 Front Load Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Washer wont start or reset
All I did was clean the filter behind the kick plate. Works fine now.
Sep 13, 2008 | Hoover H130E Front Load Washer
Front Loading Duet Washer will not start
You have to set your programme FIRST, then put the "on" switch. Try.
Mar 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
157 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
