Question about GE JE1540 Microwave Oven
GE microwave My Microwave doesn't cook any more. The light is on, the turntable goes around, and the fan works.
  • 5,911 Answers
This is usually an indication that the magnetron has gone bad, or something in the high voltage network controls the magnetron. Any one of the following components could be at fault: 1. Magnetron 2. High Voltage Transformer 3. High Voltage Diode 4. Magnetron Thermal Cut-out 5. High Voltage Capacitor 6. Interconnecting wiring I do not advocate taking any voltage measurements inside the High Voltage section of a microwave since the voltages can be as much as 14,000 volts or higher. If you are savvy enough to attempt yourself, WITH THE MICROWAVE UNPLUGGED, you will need to disassemble the unit to get to the high voltage section and take resistance readings. The magnetron or diode are likely suspects. If the magnetron or the transformer are bad, the repair costs can meet or exceed the price of the oven. Let me know if you need further assistance.
Posted on Jul 16, 2007
SOURCE:
GE Advantium Oven stopped working
Could be an open internal fuse, magnetron, or control board failure
Aug 29, 2017 | GE Microwave Ovens
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
GE Microwave Model: JVM1540DN1BB Keypad appears to work... but Microwave doesn't work
The problem is more than likely in the microprocessor control board, sometimes a bad relay, or poor solder points.
Mar 11, 2012 | Microwave Ovens
Everything appears to work but turntable and light on interior.
It's probably your bottom door switch. See this helpful file.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 04, 2010 | GE JVM1740DM Microwave Oven
GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Sep 11, 2009 | GE JVM1750SMSS Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave Ovens Logo
144 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
