Question about Kitchen Ranges
I have a kenmore elite s017, 34235 central vac. The power for the central vac in the garage will not come on. I am not sure how to check the fuse. It appears to be a switch, but will not toggle (marked 15 amps)
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Dishwasher Problem
The dishwasher should have a thermal fuse mounted to the control board behind the operator console4.gif. It is a small silver colored device4.gif attached to a white plactic bracket. In some model dishwashers the wrong gage wiring was used causing the wires to heat up and trip the thermal fuse. There was no apparent risk of fire or anything like that, but the thermal fuses didn't tolerate the heat differential too well. A fix for the problem was to purchase a thermal fuse replacement kit (found at most appliance repair stores) that had thicker wires. The part number for the thermal fuse kit is 959376 and the price is $16.85. You can find it at repairclinic.com. Order on line and have the part shipped directly to you. Now...to access the control board perform the following:
1. Turn off the main breaker to the dishwasher. This is important. Even though the dishwasher is not running, the control board still has live voltages present.
2. Open dishwasher door and remove the top screws that hold the console in place. You shouldn't have to remove the lower screws unless you plan on removing the entire door panel.
3. The control panel should pull off from the front enough to where you can access the control board. There is a thermal fuse mounted on the board with two wire leads going to it. The fuse is silver in color and mounted to a plastic bracket which is mounted to the control board.
4. Cut the wires on the old fuse and splice the new fuse kit to it. Leave plenty of wire to accommodate. There will be instructions included with your replacement kit. Ensure you follow the direction thoroughly and tighten the wire lug screws securely.
NOTE: Do not attempt to reuse the existing wires by simply unplugging the old fuse and replacing it with the new one (been there). The fuse will eventually blow again. Follow the instructions provided and you can't go wrong.
If you have any further quesitons, or if you run into trouble during your repairs, let me know. Good luck to you.
PS If you do not wish to order on line, take the part number I provided you to any major appliance repair shop4.gif and they SHOULD have the part available. This is a known problem and a common fail item.
Posted on Dec 15, 2007
SOURCE: Power Switch for Fantom Lightning
outdates.ecrater.com just make sure your power switch looks like the one pictured..thanks
Posted on Apr 19, 2008
CorvetteKing
  • 108 Answers
SOURCE: Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Posted on Jun 05, 2009
  • 430 Answers
SOURCE: on my kenmore central vac no power unplug unit
Please clarify that we are talking about the central vac LED/switch panel panel and plugging it into a 110 V wall receptacle.
If I understand when you unplug from the power source ,then plug back in the green LED comes on, looking normal ? But when you manually activate the switch on the motor housing of the vac itself the vac does not start and the LED goes out, so no green or red LED at that point?
If this is the case , Kenmore CV's built approx 5 years ago (MADE by EUREKA) and prior had a circuit board with attached cord (as opposed to detachable) which was prone to relay failure. There were several symptoms, most common was that the relay on that switch panel /circuit board would fuse on and the vac would continue to run when the hose was detached from the wall.However some I worked on from that era had exactly the same symptom you describe. If your unit is between 5 and 10 years old and this sounds accurate, you can unscrew this curved side panel relay with one philips screw. Inside on the PCB will be an L shaped black or white 24volt relay, generally rated at 10 amps. The replacement board or relay will be rated at least 24V/ 15 amps or more. If you can isolate your motor and test it separtely with a power cord or meter , the realy/board will be the only control componnet left.
If you have a small tipped soldering IRON, not a gun, you can generally find a replacement relay to rebuild the board for about $6 at an electronics parts store. Otherwise you will need to replace the control board itself, anywhere form $45 to $70 plus service call if you have a tech come out to the house, and the tech will just unscrew , detach wires and replace the board, no repair , approx 15 minutes work. This will likely cost over $100.
Please post back with your results
Posted on Oct 25, 2009
luke_bradfor
  • 662 Answers
SOURCE: my son bought an amp and subs for his truck. they
The 'remote' terminal is powered by a lead that is normally connected off the head unit...if it has this feature...the head unit, if a good quality one' will have a blue wire that will turn on the amp, by providing a signal to it.........if not, you can bypasss this
Posted on Sep 20, 2010
Why Kenmore Central Vacuum wont power on?
The unit is overloading proberbly because the motor is seized or burnt out
Remove motor and bench test
Aug 09, 2014 | Kenmore Vacuums
My central vac unit does not turn off even when hose is disconnected. I have to unplug the motor unit in the garage to shut it off. What do you think the problem is? It is a 7 year old Electrolux
Possibly the power module. Or a short in the wiring. Take it to the local Aerus Electrolux store and have it checked by a service tech to be sure. The pm is a lot less expensive to replace than a whole cv.
Nov 21, 2010 | Electrolux Central Vacuum
Kenmore elite error code f21
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Apr 28, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he14. What is the f14 error?
EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
If there is an error reading this data, it will cuse this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Feb 18, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
Central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Jan 23, 2009 | Vacuums
Nutone cv353 central vac blew up
My guess would be that the motor is done. Impossible to diagnose for sure without seeing it of course. If you were happy with the unit before the trouble, a replacement motor will probably run $250-$300. If you are interested in a new unit, shop around. There are definitely better designed and more powerful units out there, although some of them can cost quite a bit more than $300. Good Luck!!
Dec 14, 2008 | Broan-NuTone CV353 Central Vacuum
Central Vac does not shut off
Sounds like the relay that is in the central vac unit is stuck to the ON position. When you plug it back in..does it start right up ? If so.. You should be able to disconnect all the receptacle feeds to the central vac unit at the central vac unit to determine which one ( if any) is calling for the vac to stay on.. if none are.. then it is internal to the vac and may be a stuck relay... Hope that gives you some ideas to check...
Aug 28, 2008 | Vacuums
Kitchen Ranges Logo
113 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
