Internet problem and mbr
I am using fedora 9 i am havin problems with doing internet , i hav activated my network card , and the broad band is connected but tthe mozilla firefox says that not connected whenever i open , i am not able to install the tar of cairo box and xmms player what to do?
  • 112 Answers
Use this command
#setup
set up the ip address then restart the
#service network restart
then use internet
Posted on Jan 26, 2009
How do i find my access point name my broad band t-mobile & im working with windows 7 if any one can help that would to great thanks
Your "access point" means the thing that your computer connects to in order to get on the internet. An "access point" can be the dsl modem, a router or switch inbetween the computer and the internet connection or the point of entry to the internet - depending on what you are using to connect and get on line.
You mentioned you have a broad band connection with t mobile. Is this the T mobile home service link that gives you regular phone service and internet? If so - what is the name of the box your connecting your phone and pc to?
What is the name of the equipment that t mobile gave you to use that broad band link?
Are you using a desktop or a laptop? Wireless connection? or a wired connection with a ethernet cable (looks like a phone cable but a little bigger on the plug end)?
To answer my questions go back to your original problem posted on fixya and use the comment or reply link in blue.
Mar 26, 2011 | Sony Computers & Internet
How can i connect the router? i got a intellinet 192.168.1.1 there is one wan and 4 ports are there.i have dialog broad band connection.how can i connect it?or iwant to install any software?
This is very easy to do and you should have no problems doing this. The first step to installing it connecting your router to your broad band router through the wan port. All you do it take your Ethernet cable that went from your broad band router to your computer and attach it to your new routers WAN port. next wile your new router is turned off, turn off your broad band router and then turn it back on wile it is booting up turn on your new router this is not always necessary but it will make sure that they sink together properly. And that's it your done just hook up all of your other computers to the remaining ports and they should work with out a problem.
PS. this is just the basics of setting up your router if it has wireless you may want to think about implementing some security measures such as encryption.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Intellinet Active Networking Intellinet...
I am having connection problems with my Belkin G wireless CAB5FF router ......It will not connect to the internet, if it does connect to the internet it will drop off, even when it saids the strength is...
What kind of internet carrier do you have, if you have a DSL, you have to use the ppoe setting, and if its a broad band, use the dynamic, and check the time/duration setting on your router. DO you lose connection using another pc on the network? If not, the wireless adapter on your laptop might be the problem. Upgrade the firmware
Mar 03, 2010 | Belkin Computers & Internet
Can someone please tell me how to connect to the internet so I can send text messages on my psp?
For this you need a broad band connection.Now switch on the psp go to settings go down fully and enter network settings and enter infrastructure mode.There select [New Connection] and you will enter WLAN settings there select scan.While doing this remember to do this switch on the broad band so that the psp will be able track it while scanning.After it finds your WLAN it will show you the SSID,Security and signal strength.Then press 'x' and type the SSID and press the right arrow to continue.Now you mus type the security code if you have one otherwise press none.Then select the address settings to easy or custom and keep going front until you find the sentence 'Press the x button to save settings'.Now you can browse the internet with the connection.But remember to switch on the broad band when you want to browse the internet.
Jan 27, 2010 | Sony PlayStation Portable (PSP) Console
I want to access the internet on two computers using cricket broad band
You have to connect the computers directly through the ethernet ports, then go to network connections in the control panel and click set up home or small office network and then you have to set up the computer with the internet as the host and the other as the guest computer.
Jan 09, 2010 | Computers & Internet
How to set dsl modem
You go to start menu and access the Control Panel. Open Network Connections and make sure the LAN connection is enabled. If not, right click and select Enable. After confirming LAN connection, then go back a page and click Internet Options. Then the page will automatically show you the General Tab. Type in (or verify) home page in the window. eg. www.aol.com . Then select Connections Tab. Remove any connections that appear in the window below. Below that on the same page, select LAN Settings. Check the Automatically Detect option. This will allow your PC to detect your modem and your internet service. Select OK at the bottom and the window will close. Click Start again and select the Internet Explore. If your internet service is active the window will open to your home page. Good Luck!
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Dsl faullts
You need to check your DSl line to your Internet Provider so they can properly setup the right configuration for your DSL connection so this problem wont happen again...
Hope that helps..DOn't forget to rate the solution FIXYA thank you...
Oct 05, 2008 | Computers & Internet
How to improve my internet speed
hi Prem,
If you are using 256 Kbps broadband and you have installed 10 PC in ur network with Star topology then i dont think it shold be creating the problem. Star topology holds best compatibility in a small network.
The Problem would be causing because of your network card.
Network Card (NIC) plays most important role in ur network for transmitting and receiving data efficiently and fastly.
So you would need to check out for ur NIC card first i.e what catagory of NIC are u using?
You need to upgrade ur NIC in the server and also in ur client's PC.
Different catagory of NICs are-
1. 10 Mbps
2. 10/100 Mbps
3. 100 Mbps
It is recommended to use 100 Mbps NIC card for best performance in ur network. This will surely improve your net speed.
Another cause of ur slow speed is your broadband speed. If you have Cyber Cafe then you should upgrade with atleast of 512 Kbps of broadband speed in your network for better performance.
And use a good broadband service provider who are using good spectrum and bandwidth.
Like - Reliance, Airtel, Sify etc. (for India Only)
The given solution will defenately help you to improve your Network. e-mail me you acknowledgement on - rock_65@hotmail.com.
Aug 01, 2008 | Microsoft Windows Server Standard 2003 for...
Internet connection
you need a modem in your ps2 slimline are built in at the back plug your ethernet cabel in the ps2 from your modem or maine line i think you will need a setup cd to play some games this hase a id and passwor for you
Jun 21, 2008 | Sony PlayStation 2 (PS2) Console
ATI Mobility Radeon? X2300 graphics driver for Fedora
If you install the Fedora 9 preview it should resolve this issue.
May 02, 2008 | ATI Mobility RADEON Graphic Card
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
