Question about Bamix Deluxe Handheld Blender
25-30 year old Bamix M100 - 240V 100W
The outer shaft is loose and rotates slightly while the inner shaft which holds the blades rotates at speed.   The outer shaft also slips up and down by about quarter inch from main motor housing casing.  Tried dismantling unit - removed 4 screws on top plate to reveal wiring but nothing else.  Then found what I thought were 2 small plastic discs that covered screwheads on either side of the toggle switch.  These discs did not pry off - instead they swivelled but did not reveal any screws!  What are these, and how can I separate the shaft from the unit to see if it can be tightened / repaired in some way?
Those small plastig bungs do come out, you will need a fine probe to prise them out then you will see 2 philips head screws which hold it all together, not sure how you will tighten your shaft though, looks like it might be moulded into the plastic retainer, good luck! on mine the motor bearings are seized,
regards,
Dave Pary.
Posted on Mar 18, 2009
How can I find a new Bamix old model spice blender/chopper
Bar mix products made millions for world wide sales
kitchen aids that change design so often
they cant support a large parts division
(R&D is geared to sell the next better barmix product )
if you cannot find a new old part
or super ceeded shaft from the next model up
or used drive shaft for sale online
look for a complete used bar mix spice blender/chopper
some people collect barmix units for a hobby or collection
and sell double ups
when you say old model
if the shaft is plastic ....... its .unfix able
its a heat molded construction process
Vintage Bamix M122 2-Speed Hand Held Food Blender Mixer-Chopper
Sep 16, 2016 | Bamix Blenders
I need attachments
It seems you can no longer buy the HA-3058 or parts for that, however Bamix sells a similar product it seems to be the same machine with only a few aesthetic changes.
They sell many accessories and you can get blades.
Check:
http://www.bamix.com/
http://www.bamix-blender.co.uk/
I have had our customers buy the Bamix blades for the MegaMix HA3058 and the blades are interchangeable on those machines.
-Colleen@ MendingShed http://www.bamix.com/ http://www.bamix-blender.co.uk/
Apr 06, 2015 | Blenders
Kitchenaide blender pitcher blade assembly sticks
You need to lock the blades from turning and undo the bottom clutch drive in such a way as you do not damage it. I use an old motor clutch drive to undo them myself. It has a left hand thread and a block of wood to hold the blade. Then you can remove the blade with shaft from the brass bush to clean and lubricate it. If the brass bush has moved up in the plastic housing you need to press/bang it down again. Then reassemble. If you wreck the clutch drive on the blade you will need to buy a new blade assy if it is separate to the beaker, if not you will need a beaker and blade unit complete.
Jun 23, 2014 | KitchenAid KSB560 5 Speed Blender
How to lubricate blade assembly.
How can I change the blade for my 2 speed hand mixer? The model type is NC-12 if you need to know
you are using your KitchenAid blender and it stops blending, you may think there is a problem with the motor in your machine. However, a common reason for the blades not rotating in the blender is a dirty or faulty coupler. The coupler is what connects your blender dispenser to the motor, and you can easily replace the coupler at any time by only using a screwdriver.
Things You'll Need
  • Flat-blade screwdriver
    • 1 Turn the blender dispenser clockwise and lift up to remove it. Set the blender dispenser aside.
    • 2 Insert a flat-blade screwdriver between the black drive coupler and the frame of the blender on the top center portion of the blender.
    • 3 Lift the screwdriver upward, and the coupler will start to bend out of place. Slightly turn the coupler and then lift up on the screwdriver again.
    • 4 Continue to move the coupler slightly and lift the screwdriver until the coupler is completely removed.
    • 5 Insert the new coupler over the blender's motor blade and then twist the coupler counter-clockwise until it is tightly fastened.
Jun 07, 2011 | Blenders
How do i change the blades to change function
Website for company: http://www.bamix-usa.com/
Search by model on the site; they have streaming videos that may answer the issue.
May 17, 2011 | Bamix Deluxe Handheld Blender
Old bamix - motor on but the blade does not turn. unscrewed the bottom casing and cleaned out the oily part but still not working?
If possible, check the spot where the blade fits onto the driveshaft. It's probably a toothed gear or wheel. I have had blenders "die" before due to wear between the drive shaft and the blade. The blade would bump along inconsistently as the gear teeth failed to catch.
May 03, 2011 | Bamix Mono Handheld Blender
I have a bamix M200 hand blender & the shaft does not turn although the motor is working can you help?
After a period of time food residue will migrate up through the seal on the "foot" and lodge in the shaft. Once this is gummer up the motor will go but the shaft will not be able to rotate.
The machine will need to be disassembled and the shaft cleaned out. I recommend that you find your local Bamix Service Centre to do this as there are fragile parts in the stick mixer.
May 21, 2010 | Bamix Deluxe Handheld Blender
The nut that holds the blade is loose and liquid gets through it. When I tried to just tighten the nut is spins but does not tighten. Is there a trick
It sounds like the blade has overheated at some point. When this happens the plastic melts and the seal is broken. The only repair is to replace the blade unit:
http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
Jan 07, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
I am unable to remove the blade, what can I do
the blade is a screw fit on the shaft of the blender,, if you only use one blade just rince the blade under the tap and dry it off before putting it away, the only way to un-screw the blade if its stuck is give it a sudden jolt on the side of the blade with a soft hammer in the same way as it turns,,this may shake it lose,,,not to hard though,,,
Nov 15, 2009 | Bamix Mono Hand Blender - Black...
Bamix Deluxe Handheld Blender Logo
1,580 people viewed this question
Top Bamix Blenders Experts
Ruth summersides
Stan Ford
Mai Lor
Are you a Bamix Blender Expert? Answer questions, earn points and help others
