Question about Honeywell QuietCare HCM-630 Humidifier
Where can you buy undiluted virgin white vinegar
4 Suggested Answers
SOURCE: Having trouble finding Undiluted white vinegar for cleaning
I think undilluted means don't add water to the stuff you get at store. Just straight from bottle. If it says 5% dilluted this is still ok.
Posted on Dec 31, 2008
lkjhbwtgwr
Here my friend. pick one: Amazon com Undiluted white vinegar
Posted on Oct 13, 2014
rtyujkryu
Hi dolphinblu...
Amazon offers pretty large number of articles (Undiluted white vinegar), click here Amazon com Undiluted white vinegar and pick one (who fits your needs, price etc..)
I hope this was helpful. enjoy
Posted on Nov 19, 2014
Hunter Humidifier #33222
From The Hunter Manual
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes.
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOUR HUMIDIFIER to continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Jan 16, 2009 | Hunter CareFree Plus 33222 Humidifier
How do I clean Hunter Humidifier #33222 ?
From The Hunter 3322 manual.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Not adding moisture to the air
Have you cleaned the unit lately? The following is from the owners manual.
Jan 04, 2009 | Hunter CareFree Plus 33222 Humidifier
Cleaning water tray
I usually just balance the tray upside down on top of the base and fill the edges with vinegar. You could also put the the tray in a bowl filled with vinegar and submerge the whole thing.
Dec 19, 2008 | Honeywell HWM-450 4 Gallon Humidifier
I need to know how to clean my filters on Hunter Humidifier Model # 33222. I have misplaced my instructions.
The instruction manual suggests using the water vinegar solution.
The following is from the manual.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location.
Dec 18, 2008 | Hunter CareFree Plus 33222 Humidifier
Hi dolphinblu...
Nov 20, 2008 | Honeywell QuietCare HCM-630 Humidifier
Cleaning
For Model V745A Vicks Warm Mist Humidifier:
Weekly Maintenance (Removing Scale)
  1. Turn the switch to off and unplug the corn from the wall.
  2. Remove Water Tank and empty any remaining water from the water tank.
  3. Remove Medicine Cup from the Cooling chamber from the Base. Carefully remove the Cooling Chamber and Removable Water Tray from the Base.
  4. Soak the Removable Water Tray in a solution of white vinegar and water for 20 minutes. Rinse thoroughly and then wipe dry with a soft clean cloth.
  5. Fill the heating chamber with undiluted white vinegar. Let stand for 20 minutes. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Heating chamber to remove scale. DO NOT use soap, detergents or abrasive cleaners.
  6. Rinse the Heating Chamber using clean warm water, being careful not to submerge the base in water.
  7. The Water Tray, medicine Cup, and Cooling Chamber are top shelf dishwasher safe.
May 23, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
My Bionaire Humidifier
From the user manual (which is online)
2. Clean the base by partially filling
it with one 8-oz cups of undiluted
white vinegar or by using Cleanse
CleanTM Solution (DMS216) by the
manufacturer. Leave this solution
in the tank for 20 minutes, while
cleaning all interior surfaces with a
soft brush.
May 19, 2008 | Humidifiers
Humidifier does not reset
According to Holmes, one of the causes of the Reset light staying on is scale buildup on the heating element.
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the base by partially filling the base with one
8-oz cup of undiluted white vinegar. Let solution stand
20 minutes, cleaning all interior surfaces with a soft
brush. Dampen a cloth with undiluted white vinegar
and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the
white vinegar solution before beginning to disinfect
the tank.
4. Wipe the heating element clean with a soft cloth after
it has had chance to cool.
If the scale has really built up it might take longer than 20 mins for the vinegar to get rid of it and you might need to refresh with new vinegar.
Your Manual can be found at this link:
http://www.holmesproducts.com/Manuals/Holmes/HM5250-UC_English.pdf
Good Luck.
Apr 07, 2008 | Holmes Products HM5250-UC Humidifier
Cleaning the filter
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Mar 12, 2008 | Hunter 33202 Humidifier
Honeywell QuietCare HCM-630 Humidifier Logo
85 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
