Question about Utilitech Plumbing
Weep hole for a utilitech pro sumbmersible sump pump?
Do I need to have a weep hole for the sump pump
SOURCE: 04 yfz 450 water pump leaking from weep hole
you get the impeller of from removing the complete side case ( not only the water pump cover) then you can remove the water by unlock the internal water pump shaft....replace OIL SEAL
93109-11073-00 and also OIL SEAL,SD-TYPE
93102-12321-00 just to have you're mind in piece..they are so unexpensive that you d'ont wanna take any chance for 4.00 usd.....cfb12e5.gif
Posted on Oct 02, 2009
  • 51 Answers
SOURCE: 2003 yamaha leaking through weep hole
yes your water pump is gone ,will need to replace,this happens when the bearings give out,cheers roady
Posted on Feb 15, 2010
  • 119 Answers
SOURCE: do you still sell the pump that will oump to floor
They make self priming pumps that need no pit.
Posted on Mar 29, 2010
  • 105 Answers
SOURCE: leaking coolant out of overflow and leaking out of
hello sounds like its running hot to be pushing out of overflow, you will need water pump if its coming out of weep hole, good luck
Posted on Mar 31, 2010
Testimonial: "Thanks for the help. "
emissionwiz
  • 80637 Answers
SOURCE: water weeping from the overflow weep hole in the
that is not an overfill hole it is a seal and bearing drain hole, this means the shaft seal has failed, u will need to replace the water pump
Posted on Apr 17, 2010
Testimonial: "This would account for the rattle i can here also from the pump. Many thanks Ian "
02 trailblazer overheats and appears to have leak from oilpan?
check for the leak at the weep hole of the water pump as that runs down onto the lip of the sump and runs around
have the system pressure tested to prove where the leak is from
Sep 16, 2017 | Cars & Trucks
Impeller runs, no water comes out. Removed output hose, air is blowing out when removed from sump.
Remove bottom cover, check for clogged intake holes, and make sure the impeller is solidly attached to the shaft. Can you see the water in the sump? Is the sump full of sand at the bottom?
Jun 28, 2015 | Utilitech 1/2-HP Cast-Iron 83 GPM...
Sump pump does not go on all the time have to shake pipe to get it going so water doesn't overflow
There should be a float switch in the pit, sounds like its getting stuck and when you shake it it activates. Check the switch, the rod, etc.
Mar 01, 2015 | Utilitech 0.33-HP Thermoplastic...
Sump pump will not pump water, won' turn on, floater up
There are a few things that could cause this problem to come up. Pretty much all of them do require taking the sump pump apart a bit though. I would suggest having a professional come to help you if you don't have much experience with this kind of work. Hopefully you can get this resolved fairly quickly.
http://www.rite-waywaterproofing.com/sump_pump_install.php
Apr 30, 2014 | Utilitech Plumbing
Weep hole
THE WEEP HOLE IS THERE TO TELL YOU THE BEARING AND OR SEAL IS GOING BAD.NOT A GOOD IDEA TO PLUG IT.
Jan 03, 2014 | Cooling System for Kia Rio
I purchased a Simer 3986 SS Pump. Need proper mounting location for check valve. I have a manufactured weep hole in the threaded area of the check valve, Pump runs, water level trip vertical float switch...
Thank you for posting your question here on Fixya.com.
The orientation for a sump pump/check valve are the pump is in the bottom of the pit, the discharge pipe leads up into a check valve, usually very close to if not threaded into the pump discharge, and then the pipe continues up and out to wherever your water discharges to. The weep hole needs to be below the check valve.
The hole is there to prevent an air lock in the pump which would prevent it from moving water.
If the water trapped in the vertical run of the discharge pipe is returning to the pit once the pump shuts off the problem is the check valve is not holding or the hole is on the wrong side of the flapper assembly. Did the check valve come with the unit? If not, you will need to fix it if you can or replace it.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Feb 23, 2011 | Flotec SimerOmni 3986 SS Sump Pump
How to troubleshoot toilet sump pump?
Unplug the sump pump. Bail out the sump pump to expose the pump's machinery.
Inspect the rod attached to the motor on the top of the sump pump. Move it up and down manually to see if it moves smoothly. Corrosion will keep the rod from moving smoothly. Clean the float road with steel wool.
Inspect the float ball. If it contains water, you need to replace it. Unscrew the float ball from the end of the float rod and screw on a replacement float ball.
Inspect your sump pump's check valve. It has an arrow on it. The arrow should be pointing away from the pump. If it's pointing towards the pump, remove and reinstall the check valve.
Locate the small weep hole between the check valve and the pump. Clean it out with a pipe cleaner.
Inspect the impeller, which is the fan-like piece that sits near the bottom of the pump's tank. If it is clogged by debris, then it will not turn properly. Unbolt the impeller and clean away any debris you find. Reinstall the impeller with new gaskets and sealant. Locate and replace the mesh filter in the sump pump, since only a damaged or missing filter would allow debris to get near the impeller.
Below is troubleshooting work, web link, through to assist you in that.
http://www.plumber-washingtondc.com/articles/sump-pump-troubleshooting
Jun 25, 2010 | Plumbing
Water problem
That is most likely your weep hole and it means your water pump seal is leaking. You should rebuild the pump at a time that is convenient to you rather than have the pump quit on you while you are riding some day. I have had a tiny leak for years, but sometimes they go fast.
Feb 28, 2009 | 2005 Yamaha YZF-R1
Plumbing Logo
135 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
Dave
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
