Question about Goodman Manufacturing GSX130361A/GKS90703BX/CAPF3636B6 - 3 Ton 13 Seer 92.1% Efficient 70,000 BTU R410a Goodman Gas Furnace Air Conditioner System
Gks9 short cycle no codes
Burner comes on for 2 seconds and cuts off solid red light on
When charging the red light will cycle 7 seconds on then 2 seconds off and constantly repeat this cycle. However, the instructions state when charging the red might will stay on until fully charged. What...
Sounds like battery is no good There should be symbols on charger. Normally solid light charged. Blinking. Charging. Lights back and Foward battery. No Good won't accept charge
Mar 25, 2015 | LG HBS-700 Bluetooth Headset
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
Wii has solid red light, won't turn on, faint ticking noise
if it was dropped check the bluetooth module , they can come unplugged and the wii will not function. Children love to put change in the wii which can short it out. Never bridge a fuse as it can cause unsafe conditions and potentially a fire hazard .
May 08, 2014 | Nintendo Wii Video Game Consoles & Games
Reprogram the remote,how?
1. Turn on the device that you want to set.
2. Aim the remote control at the device and press down and hold CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the LED light will blink once and then remain solid red.
4. Using the number keys, enter the 3-digit code. After you have entered the 3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times. You will then need to repeat Step 2. You have 30 seconds to enter a code.)
5. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying to program powers off, then you have found the correct code. If the device does not power off, then you will need to repeat the process again from Step 2, using another 3-digit code.
The manual can be found at jumboremotecontrol.com
http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Apr 06, 2014 | Innovage Jumbo Remote Control
When call for heat on model # WGPH-10eamer serial number DF5D302f419801914 the furance goes throught the cycles, the burner comes on and cuts off after 8 seconds. The flame censor was changed and the...
It could be the control board, But before I would replace the board I would check to see if the flame sensor is not touching the burner and shorting it out. Also check the flue make sure it is open. This has a combustion blower on it and a proving pressure switch. Some time the pressure drops when the burners come on will trip the switch and start the process all over again and acts just like a flame sensor fault if the flue has some blockage. Also make sure you have a good ground back to the board. A little rust on the burner right at the flame sensor can block the micro signal back to the board. I am sorry I can't remmember the light codes. There should be sticker on the panel with the wiring diagram that show the codes. Good Luck I hope this helps....
Feb 06, 2011 | Weather King Heating & Cooling
Dryer doesn't dry (flame cuts out)
279834 is the part number for the 2 coils ( kit ) which mount on the burner . Only 2 screws hold the coil retainer . One coil is opening ( shorting ) after it gets warm . Replaceing both will solve the problem . Easily replaceable .
May 29, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Playstation 3 (PS3) Console: i had a power cut whilst playing ps3 , now it wont...
First thing to try is a video reset.
While the PS3 if off (red light solid) hold down the power button until you hear the SECOND beep, quickly release.
Let me know if this works, otherwise we'll try step 2.
May 16, 2010 | Sony Playstation 3 (PS3) Console
Heater short cycles burner fires up won't stay on for long fan kicks on and chamber cools down and short cycle starts over again.......ther is a solid green led indicator lit up and I can't find so far...
i take it the burner is pizo fired(electrically ignited), if so, there is a flame sence wire down by the burner that senses the flame, if it don't, it shuts everything down for a short time then tries to restart. check senser at burner or circuit board.(a little more info would've been nice)
Jan 31, 2010 | Heating & Cooling
Power light cycles to red, no other lights on
Hi der... well the issue your facing is simple to say ur power adaptor is faulty. Usually its due to some electrical shorts or maybe some heavy lightnings. You can always have a remedy for it.
1st : Buy a new adaptor.
2nd: call ur ISP to have it replaced if ur still under some contract term or if the modem is still under warranty.
3rd : you can buy ur own ADSL2+ modem from supporting outlets . Make sure ur isp supports this modem.
This are the solutions for ur problem pal.. So make a wise decision.. Any needs and help post it to FixYa..ANd the experts here will fix ya..!
Jun 27, 2009 | 2wire (1000-000057-000) Modem
Goodman Manufacturing GSX130361A/GKS90703BX/CAPF3636B6 - 3 Ton 13 Seer 92.1% Efficient 70,000 BTU R410a Goodman Gas Furnace Air Conditioner System Logo
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
snowmanii
ray gallant
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
