Question about Miele DA409 Kitchen Hood
How do I get the red light to go off on fan - Miele DA409 Kitchen Hood
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
That is just a reminder based on operating time to clean the filters. Just hold your finger on the clean filter button for 10 seconds to reset it, as per the operators manual.
Posted on May 06, 2017
Pawtucket ceiling fan model 40692. My old fan ran on two wall switches, which gives me an extra red wire and the manual does not say where to connect the red wire
One set of wires is for the on/off switch to the fan and the other is for a light package. Just cap off the end of the red wire (its alive) if you have no light attached to the fan. Some fans have a light wired into the fan with 2 hanging bobs on a pull chains. One chain to the fan speeds and the other to a light.
Jan 31, 2018 | Dryers
Help. I need help properly connecting wires on a new ceiling fan.
Usually, the fans with remotes will dim the lights by holding the light button for a few seconds. So, the red wire would stop this feature if wired directly to the fixture. That would eliminate the wire coming out of the receiver for the lights. If you want the light to dim, then tape off the red wire, so the remote will dim them. The wall switch won't work anymore. If you want to connect the red wire , tape off the wire from the receiver that connects to the light sockets and connect the red wire to the wire for the light sockets. This will operate the fan but the remote will not dim the lights. If you have a motor speed controller in the wall from the old fan, remove it and replace it with a switch or eliminate the switch altogether so the remote will control the fan speed.
Nov 13, 2016 | Dryers
CEILING FAN MODEL AM-1
The red wire is the hot wire for your light so connect it to the black wire on your light. The white neutral wire should connect to your other white wires on fan power wires.
Sep 02, 2012 | Hunter (25417) Ceiling Fan
I have 2 wall controls for my current fan. One is for the light on the fan and the other is for the fan itself. When I disconnected the old fan, there were 3 wires - black, white and red. What do I...
Both the Red and Black wire are your hot wires. One is probably for the fan side and the other the lights. The white is your neutral wire or common and is used by both. So the wires from each switch are HOT, hook one wire to the black and the other switch wire to the red.
Jun 05, 2011 | Hunter 52" Ceiling Fan With Light And...
Im installing a remote to Hunter fan w/light. A White n Black coming from fan, Remote has Red,Black,White n Black n White to go to ceiling.Where do the red,black n white from remote go to on the fan? Thank...
Black goes to the black on the fan white goes to the white on the fan and the red will go to the blue wire on the fan for lights. Now if you have a black wire with a white stripe on it from the fan that is the light wire.
Apr 20, 2011 | Hunter (25417) Ceiling Fan
House wireing red,white,black. how do i hook up a cealingfan with light kit pull chain on.
For starters, look at the wall switch. Are there two switches? If so, connect the black wire from the ceiling box to the black wire from the fan. Connect the red wire from the ceiling box to the blue wire from the fan. Connect white to white. At the fan, usually the black wire goes to the fan and the blue wire goes the the light.
If there is only one wall switch, you may or may not want to install a double switch so the fan and light can be controlled separately. If there is only one wall switch, most people just connect the wire connected to that switch (usually the black) to both the black and blue from the fan, not using the red at all. In that scenario both the light and the fan are switch at the fan as needed after the wall switch is operated.
Installing the extra red wire is not usual practice, someone actually was planning for future use and convenience.
Apr 16, 2011 | Solar 2-wire Pull Chain Light Switch For...
I am adding a light to a Hampton Bay fan. From the ceiling wiring I have a red and a green wire that are not connected. Is the red wire for the light and do I tie it in to the black wire to the fan for...
The green is a ground and the red is the hot wire for the light. One wire from the light kit is white and should be connected to the other white wire in the fan. The red wire should be the hot wire and gets connected to the black or blue (other wire) from the light kit. If you connect the two wires and the light does not come on, you need to find the other end of the red wire and make sure it is connected to a switch to give it power. The other end of the red wire is probably in the single gang box where the wall switch for the fan is located. Or you can tie the red wire for the light to the black wire for the fan and simply use the pull cord to cut on/off the light.
Jan 26, 2011 | Heating & Cooling
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
My home is pre wired for a ceiling fan in the master bedroom. There are two light switches that control the pre installed wires. One for the light on the fan and one for the fan. There are four wires
The usual wiruing for these fan/light circuits is that the black wire on one switch is for the fan and the red on the other switch is for the light. If you are using a remote set up for both fan and light, then hook the remote wires to the black and white wires in the ceiling, You can cap off the red wire in the ceiling as this will not be used.
Apr 24, 2009 | Hampton Bay 24002 Ceiling Fan
Wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Oct 20, 2007 | Hampton Bay 24002 Ceiling Fan
Miele DA409 Kitchen Hood Logo
Top Miele Kitchen Ranges Experts
Jim Thurston
Steve
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
