Question about JVC RX-6030V Receiver
Hello i have a receiver jvc rx 5022 vcl . can i use speakers 120watt per channel?
SOURCE: JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Posted on Jan 14, 2008
SOURCE: jvc rx 318
did you find a manual? I have this stereo and the manual if you need some help.
Posted on May 06, 2008
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
  • 51 Answers
SOURCE: speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Posted on Jan 02, 2009
lynchms
  • 93 Answers
SOURCE: JVC MANUAL
http://resources.jvc.com/Resources/00/00/96/LVT0018-001A.pdf
Posted on Mar 04, 2009
Can't get my center spkr.to work on my jvc rx 807v receiver
Make sure the speaker is good by connecting it to a known good working site. If speaker is good, make sure it is properly connected to center speaker terminals. Then if it is a surround receiver make sure that the sound mode is one where the middle channel works such as 5.1 DTS, etc. If the center channel still does not work then the problem lies with the decoder chip that is not working properly and sending the center channel info to that specific amplifier.
Mar 10, 2015 | JVC RX-807VTN Digital Surround System...
JVC RX-801V - No sound from right channel in speakers or headphones.
I'd troubleshoot first, even though you've already tried the headphones (good thinking). Get a battery (AA battery works) and put the black and red wires on opposite sides to see if the speakers are working.
Is there a menu of settings on the jvc, and is it set to 5.1? Just trying to help...
Jan 15, 2012 | JVC RX-8010V Receiver
My speakers are playing through the tweeters only (i think). there is no bass whatsoever, but the speakers do not sound blown. i have tried adjusting all of the bass that i know of. the model number for...
For all we know you have the speakers defined as 'small' and all bass from their channels is being redirected to a subwoofer. Have you looked at the manual and adjusted all the speaker levels with test tones?
Sep 13, 2011 | JVC RX-6000V Receiver
My left channel in my JVC RX-305 isn't working...what do I do to fix it? When I either push the volume up or down it makes a clicking sound. It was working just fine last night. My right channel is...
Try swapping the speakers or just check the left connections WITH POWER OFF. Disconnect the left speaker completely and see if the clicking stops.
Sep 05, 2011 | JVC RX-618V Receiver
JVC RX-888V 5.1 Channels Receiver can not get the rear speakers to work at all. switched the wires from back to front and they work so the speakers and the wires are OK. tried to press all the buttons and...
If you can via experimentation confirm that your amps are ok then the issue lies with the Dolby IC chip that controls the various sound modes. It went on my Pioneer and I had hassles getting the various speakers to work properly under different sound modes. Replacement, not cheap, cured my issue.
Sep 10, 2017 | JVC RX-888VBK
JVC RX-7030V - Overload - Protection
the transtistors are mounted to a large heat sink. and yes all 4 main trany's need replaced. you can go to the library and look in sams photofact for the service manual. the part #ers are on the transistors. have fun and good luck again.
Mar 09, 2010 | JVC RX-7030V Receiver
My JVC receiver won't play my left front speaker. The right one seems to work fine but when I plug in the left it is virtually silent. i too have had a few "overload" incidents and am running two JBL 8...
swap the wires around to see if the right speaker will give sound on the left channel. If it does, the it's a blown left speaker. If you don't get sound out the right one either, then the left channel ouput has a bad capacitor somewhere in it.
Jul 06, 2009 | JVC RX-6010V Receiver
Speackers
Hello 6423,
The RX-664VBK is capable of having 6 speakers connected to it, 2-front, 1-center, 2-surround and 1-powered subwoofer.
Hope this helps.
cancerags
Dec 28, 2007 | JVC RX-664V Receiver
RX-668V - Center Speaker Channel
have a tech check your set it is a bad cap that that bias a very small voltage to that circuit or it could be cold solder.good luck.
Apr 15, 2007 | JVC RX-668V Receiver
JVC RX-6030V Receiver Logo
26 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
