Question about Mitsubishi HS-U545 VHS VCR
When I put a tape in my vcr it spits it back out...
I got a Mitsubishi HS-U54 from my brother. When I put a tape in, it spits it out.....when it does catch, the picture flickers between color and black and white, and the sound can barely be heard over the white noise. I do not have a manual.
  • klynn2234 Jan 26, 2009
    Thank you!! I will try this.
    Problem Solver:
  • 9 Answers
This sounds like a cleaning and tape carriage alignment is needed, that not too hard to do if you tinker.Service on this is not too much at electronic or tv repair
Posted on Jan 26, 2009
Hs-u54 vcr has snow on video
Head amplifier circuit/module could be the problem in your case. You could also check the power supply to see if any electrolytic caps are out of tolerance or have changed value and replace them if necessary.
Here are a couple of examples of similar VCR issues I've had; some years ago, I had a Panasonic NV-F70A, with snowy video playback, and, after a lot of investigation and exhaustive testing it turned out to be the video head amplifier module that was the problem (not the heads themselves which were new) - replacing the plug-in aluminium-cased module fixed it and restored the video picture as well as the stereo audio output and flying head erase. Power supply was OK and the whole VCR good to go.
With another Panasonic (NV-J11A), it was several out of tolerance electrolytic capacitors in the power supply (another metal-cased plug-in module) that caused the snow on screen, erratic tape counter, and slightly wobbly audio. Head amp was OK in this one. I replaced every electrolytic in the PSU - and after plugging the module back in and turning the VCR on, the playback picture and tape counter were soon restored to normal - after some soak-testing, the machine went home.
You may not need to do anything to or with your machine's power supply at all but it doesn't hurt to check anyway so that you can rule it out as a possible problem source.
Dec 20, 2017 | Mitsubishi HS-U540 VHS VCR
Mitsubishi hs m50v
I forget exactly how this goes but there are two posts on either side of the mechanism that read a light signal and a center pole that goes through the round hole on the cassette that gives the light signal (no tape-end of tape). Put a piece of tape on the two side posts and see if that changes anything. Be careful: the tape now knows where end of tape is - do not fast wind/rewind to the end! The loading motor may have failed or a rubber belt has slipped off or is too loose or broken.
Oct 20, 2013 | Mitsubishi HS-U445 VHS VCR
I put the tape in and it doesnt go in all the way, the machine rejects it and spits it out
The loading basket is bad, usually caused by a bad gear linkage, repairs will be pricey.
Apr 16, 2011 | Mitsubishi HS-U540 VHS VCR
I have a Mitsubishi HSU48. The tape is stuck in the VCR. I cannot get it out. Do you have any suggestions
I had this problem with this specific machine. These answers have all been general to any VCR. The Mitsubishi HS-U448 has its motor underneath the machine. You don't have to remove the top cover at all. Just remove the bottom plate and spin the motor (the correct direction) to completely eject the tape.
Dec 23, 2010 | Mitsubishi HS-U448 VCR
I dont have a remote for my Mitsubishi Hs- U54 and I need to change it from Sp to Ep.
I have a remote for sale if you need it $20 plus shipping, and if you want a spare VCR for parts, both for $50
Aug 22, 2010 | Mitsubishi HS-U545 VHS VCR
Tape ejecting automatically
I found the spring on the tape carriage was off on one side. I reinstalled it and it fixed the problem
Dec 19, 2008 | Mitsubishi HS-U510 VHS VCR
Mitsubishi U54 VCR Recording Speed
If you have a remote, there should be a button labeled "SP/EP" or "RECORDING SPEED." Otherwise, I might try looking in the VCR's main menu.
Aug 09, 2008 | Mitsubishi HS-U540 VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Language setup for Mitsubishi HS-U510 VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Mitsubishi HS-U545 VHS VCR Logo
250 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
