Question about Car Audio & Video
I have a jensen uv8 when on radio mode speakers work fine when in cd or dvd mode i just get tweeters no door speakers i have a infinity sound in a dodge truck i also hot wire the pink brake wire to ground for dvd
  • 112 Answers
Your remote wire is wrong behind radio swap the blue and blue/white stripe wire going into cars blue wire... you'll be allset...
Posted on Jan 26, 2009
Changed Radio - now speakers don't work. I took out the Chrysler radio that had a CD and cassette in it and replaced it with an aftermarket radio. Now the speakers don't work. I got the adapter from a...
Sounds like your Gr Caravan has the premium sound package. You likely haven't hurt anything - but you may need to modify the wiring a bit. The speakers have a tweeter speaker in the center of the main speaker and the wiring goes through that. However, it only worked with the premium package. Go in to the speakers and move the wiring connections from the tweeter to the main speaker. Your other option is to replace the speakers.
Jan 19, 2010 | 1994 Dodge Grand Caravan
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
Uv8 some seakers dont work in dvd/cd mode
You have the wrong wire hooked up to turn on your amplifire. You used the blue wire but need to use the Blue/White wire!! That is an amp turn on wire Thje blue one is for a power antenna and goes dead when you put in a disc. The tweeters play because they are hooked direct to your Jensen. You'll be jamming in no time.
Larry T
Winona Lae
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html IN
Jan 26, 2009 | Jensen VM9510 Car DVD Player
Jenson VM9311TS will not play all speakers in cd mode
YES!! You used the blue wire to turn on factory amp (blue wire to GM pink) you NEED to use the Blue/White wire. That is the amp turn on. The blue wire goes dead when you play a CD or DVD because it's for a power antenna. So, Blue/White ok?
Enjoy,
Larry T
Winona Lake, IN
Jan 22, 2009 | Jensen VM9510 Car DVD Player
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
Cant get full audio when i plug my ipod to jensen UV8
double check you didnt cross the connections behind radio the yellow is for video output so mabye u got one of the colors wrong if that fails check that adapter plug (the headphone jack thingy) is it seated properly? remove it and seat it again and check how many bands the silver piece has if its only 1 u gonna get sound from only 2 speakers if u got 2 bands u get surround and 3 bands u get video also
Dec 30, 2008 | Car Audio & Video
The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
Nov 26, 2008 | Jensen VM9510 Car DVD Player
Have no sound when the cd and dvd is played
you have a factory amp in your vehicle so what you need to do is take out the uv8 and make sure the remote wire from the unit " blue and whit stripe " is connected to the remote wire of the car harness.
the way you have it now is the power antenna wire " solid blue " the is connected to the remote wire of the unit
Oct 29, 2008 | Jensen VM9510 Car DVD Player
Jensen head unit VM9311TS no sound from CD
Should wire HU's Power Const to Amp's Remote On. Instead you wired HU's Power Antenna to Amp's Remote On. So the stock amp got triggered only in radio mode.
Jan 24, 2008 | Jensen VM9020TS Car DVD Player
TweeTer Not working.
The only way I can think of to check is to disconnect the leads to the tweeter, then check resistance with an Ohm-meter...no reading means dead speaker.
Dec 28, 2007 | Car Audio & Video
Car Audio & Video Logo
150 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
