Question about Whirlpool 24 in. DU920PW Built-In Dishwasher
Dishwasher filles up with water between running it. I have to run the drain cycle at least once or twice daily. I have shut off the water valve to it for now.
    Novelist:
  • 159 Answers
Sounds like the water valve is leaking.If there is some dirt in the valve it will cause it to not fully seal and shut off. If the hapens water will leak by. Replace the inlet valve and your dishwasher will not fill when its not in use
Posted on Jul 16, 2007
Dishwasher will fill w/water but will shut off b4 cycle begins
Have you unplugged it for about 20 minutes yet and tried again?
Dec 28, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
Won't Fill and will attempt to run wash cycle when turned off and door is closed
Hello ddux97 - I understand your dishwasher has power but will not fill with water. Here are a few simple troubleshooting tips that may help you resolve this issue:
• Make sure water supply is turned on. (First check for shut off valve under the kitchen sink).
• Check the house circuit breaker or fuse box, reset circuit breaker or replace fuse.
• Check inlet hose and make sure it's not twisted.
• Does float overfill protector (mushroom shaped object in tub) move freely? This is located in the bottom left front corner of the dishwasher.
• If this is a new install, then make sure the unit is not pressed up against the cabinet and the fill tube is not squeezed closed.
• Make sure the electrical wires going to the water inlet valve have not come off. It is best to turn off power to the dishwasher before reconnect wires, it doesn't matter which terminal is off both need to be connected.
• Make sure the drain hose is installed correctly. If the drain hose is routed under the floor as the dishwasher fills water can be drawn from the tub and appear to have never filled.
• Some models of Frigidaire dishwashers use a water pressure switch that will shut off the water valve if the tub over fills. These models do not have floats.
I hope these troubleshooting tips help you in some small way.
Jun 20, 2013 | Frigidaire 24 in. PLD2850 Built-in...
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
Water pours into dishwashe and spills out when not running
sounds like you have a bad water valve solenoid, however their is a float switch on inside btm floor frt of dish washer that senses the level and cuts off the valve, however if the valve is bad then it will never shut off. good thing you were home. i would replace the water valve, that is located behind the front access panel . hope this helps
Sep 17, 2009 | Danby 22 in. DDW399 Free-standing...
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher won't fill on start
Check the following to address this issue.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Water in the dishwasher after the the cycle is complete
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Nov 19, 2008 | Whirlpool 24 in. GU1200XT Built-in...
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Whirlpool 24 in. DU920PW Built-In Dishwasher Logo
87 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
