Question about Other 200030, Nos, Aircraft Altimeter Aneroid Wafer
Diaphragm Aneroid wafers expands
I have a black spot on left side of screen, how can I make it go away?
Dead pixels in the LCD wafer; common issue with LCD televisions as they age. Replace the LCD wafer or consider purchasing a new television.
May 23, 2015 | Coby TFTV3225 32 in. LCD TV
The key wont turn
Very common problem. In 92 -02 toyota used split wafers (tumblers) in every lock on the car. It only had 2 splits out of the 8 that was in it. But over time as the key and wafers wore down they splits would become sort of crossed up. Those wafers need to be removed from the lock. The has to be turned before removal or the the retainer on the bottom of the lock housing will need to be cut out. there is one roll pin and 2 little crimpped areas that hold the face cap on the lock and 1 snap ring on the back. after removal of the lock and the things that hold it together you can put your key in it and slide lock plug out of the housing. you will then be able to see the split wafer and pull them out along with the springs under them. besure to hold all the wafers in place because they will fall out and if you do not know where they went you have another problem. i think the splits are in the number 3 and 7 possition. this will eventually happen to all the locks.
Apr 04, 2013 | 1992 Toyota Camry V6
How to dissassemble the ignition lock on a 97 lexus so i can remove the broken split wafers
What are wafers,End why are they spilt,? Tell the kids not to eat wafers in the car.LOL:
Nov 09, 2012 | Crown Ignition Lock Cylinder J Series Jeep...
I need a connector (CD to sub-woofer) for the Brookstone Wafer thin CD player with MP3.
www.stockcable.com carries what you are looking for. It's a 9 pin mini din male/male connector cable
part number R58190A-09
Jul 29, 2012 | Brookstone Wafer-Thin CD System with MP3...
Need manual for a Marshall 80 blood pressure monitor. Thanks
I have one . . . or soon will. I don't see a way to upload it here. If you contact me I will send you a pdf after I make it from my copy.
Aug 10, 2011 | Marshall Health & Beauty
TinyTunes? MP3 Player .......not wafer-thin cd
For the Wafer-thin CD system, download this... http://www.brookstone.com/bs_assets/files/pdf/product/manual/450585.pdf
Mar 27, 2007 | Brookstone Wafer-Thin CD System with MP3...
Other 200030, Nos, Aircraft Altimeter Aneroid Wafer Logo
29 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
