Question about Kenmore Elite 45986 Front Load Washer
The rubber seal kenmore 3.8 cu ft he3t king size capacity
THE RUBBER SEAL HAS COME OFF FROM THE BASKET IT LOOKS LIKE THE METAL BAND HAS LOOSENED I CAN'T FIND ANY IINSTRUCTIONS ON HOW TO GET IT BACK ON. I HAVE TH EMACHINE TAKEN PARTIALLY APART I CAN'T GET THE CONTROL PANEL OFF TO GET WHERE I CAN GET THE RUBBER SEAL AND BAND BACK O ON
I have a 3 year old washing machine bought at Sears. It is a Kenmore and it says it is model #417-43052200. My rubber seal is not attached to the drum. It came off at the bottom and water leaked to the floor when doing a load. In trying to re-attach it (very difficult) I suceeded in getting the entire rubber seal de-attached from the drum. How do I re-attach the entire seal now? Seems impossible.
Our rubber seal was torn and we had a Sears repairman replace it - he said it required a special tool to install it (which he didn't have) but through some long and physical process, he was finally able to get it on.
Posted on Jan 27, 2009
Why won't the lock disengage?
Most likely, the electric lock mechanism is jammed and/or shorted out and it must be replaced.
Jul 30, 2015 | Kenmore HE3t 4.0 cu. ft. Front-Load King...
Getting an H R error
http://c.shld.net/assets/own/HE3t_W_e.pdf
unless it is a problem or stops washer from working,deal with it or buy a new,Preferably not a kenmore or sears,sears is going under,here is the manual that says nothing about hr error,it will cost 1000's to repair,{it is old}
Mar 14, 2015 | Kenmore HE3t 4.0 cu. ft. Front-Load King...
Door wont lock, cycle doesn't start
interlock could be knackerd...................cheers
Jan 22, 2014 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
Door wont lock cycle wont start
Try unplugging the machine for 5 minutes then plug it back in to reboot it.
Jan 22, 2014 | Kenmore HE3t 4.0 cu. ft. Front-Load King...
How do you reset the computer on kenmore elite he3t steamer
UNPLUG FROM WALL SOCKET FOR 5 MINUETS PLUG BACK IN TRY AGAIN IF YOUR DRYER IS HARD WIRED DO THE SAME AT THE FUSE OR BREAKER
Oct 30, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
My washing machine gets a sud error often during the cycle. I have cleaned the drain as suggested
Vinegar does a great job of cutting suds and bubbles. I would put it in the detergent, softener, and bleach reservoirs and run a cycle. Then make sure you read the detergent amounts. It's easy to overdo detergent on a front-loader.
Aug 17, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
KENMORE HE3T BASKET RUBBING ON THE PLASTIC FRONT TUB
if ripped obvioussly youl need to replace the front rubber bellow, i would remove the bottom panel and have a look inside sounds like you have a broken shock aborber or 2 not properly supporting tub assy
Feb 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
469 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
