Question about Refrigerators
P42 Stg4 not cold enough - Refrigerators
Rear motored truck on kato ho p42 after dcc installation not working properly after period of time
I've had the same issue. I doubt it's your DCC hookup. Those motors are probably shot, and need to be replaced. I run analog, and I've had multiple motor failures with these things. These motors don't last long and, when one goes, the other one often follows... fairly soon after. I was able to prolong the motor life a little bit by orienting the motors to run the same direction. (I turned the rear truck around. I realize that's probably not possible, with your DCC in place.) I've still had motors fail, in spite of motor orientation. I've got all nine units, and six of the nine have had to have motors replaced. Some units, I've had to replace motors more than once! I haven't figured out any way to bring a motor back to life, once it starts stalling intermittently, or if it quits altogether. Sometimes, rotating the motor a tiny bit in its cradle might help, but that's a stop-gap. I suspect motor failure... unrelated to the DCC hookup.
Feb 04, 2014 | Kato HO P42 Genesis AMT PhVb 161
Vizio P42 HDTV no picture
Try first unplugging power cable for thirty minutes, then plug back, this will drain power from TV completely and will reset it.
See if it works.
Oct 18, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Cracked screen
Unfortunately if the screen is cracked the only remedy is to have it replaced which will be expensive, therefore it might be worth considering a new TV
Oct 28, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
yes you need to check the power supply board going to the pitcure tube board common problem bad transister
Oct 12, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P42 Plasma HDTV10A
THE CABLE INPUT IS SERVED ON 22" VIZIO HOW AND WERE CAN I GO TO FIX THIS PROBLEM IN ATLANTA
May 19, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Select P42 Plus
I have also got the same problem. If u got any solution then please share it with me. my mail id is ranjeet29330@yahoo.co.in
Oct 17, 2007 | VIDAR Systems Select P42
Vizio P42 dark haze when turned on
This is an ongoing issue with the Vizio 42" series. The SMPS power supply has been a problem in all the Vizio models since day 1. We repair these sets and I do not recommend them at all, they are very unreliable. The SMPS power unit is board replacement only at this time and very expensive. Joe Weibel Custom Electronics Memphis, TN 38133 (customelectronics.org)
Jan 07, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
