Question about HP Compaq nx6125 Notebook
F10=ROM Based Setup
Hello, my screen shows mensage F10=ROM Based Setup, and it does not allow me to do nothing, already retires the battery of the card mother, I form, and when the assets again, appear to me in screen the same again. Thanks for its aid.
  • Anonymous Feb 26, 2009
    Identical problem, persist even after motherboard changed (my thirst thougt - it is this baterry). Also disk crashed, so HD is also brand new.And still quite frequently - switch on and before boot notebook totally frozen with F10 message.
    The only help - patiently switch off and on with a hope maybe one times it will boot.
    A reliable remedy:
    never buy anything from HP!
    Zdenek Vasak
  • Stephen Medley
    Stephen Medley May 11, 2010
    I appreciate your trouble with English as it is a difficult language! I believe what you are trying to say is that you continually have the BIOS setup. That would be due to a CMOS or RTC battery problem. It is not clear whether you replaced that battery and whether that battery replacement was the exact replacement. Steve Medley
F10=ROM BASE SETUP
Posted on Jan 22, 2010
I have a COMPAQ Presario M2000 laptop Win XP with latest updates, 5yrs old, working fine till recently. after switching on , hear two BEEPs & can see the black screen with COMPAQ logo, then Press F1...
Hello cgilpin659,
There is usually an error code that comes with the 2 beeps post error. This link shows what the error code for the 2 beeps might mean: http://www.kiesler.at/faq14.html
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Apr 25, 2011 | HP Compaq dc5000 Small Form Factor PC...
My hp Compaq nx6120 can't starts. When I turn on screen the follow messages F10=ROM Based setup i pressed F10 but I can't go into bios. please help me!!
please help me!!
Jan 23, 2011 | HP Compaq nx6125 Notebook
My compaq evo nc620c laptop wont boot up, only goes to the "compaq" log screen from where I can go into F10 rom based setup or F12 network boot only.
Without having seen it, it sounds like a hard drive problem. Could be dead, could be the boot info has been destroyed (virus?).
ROM setup should be able to tell you more about the hard drive, and whether Setup can see it.
Apr 03, 2010 | HP Compaq Evo n620c Notebook
How to unlock my computer
this is to WARN you' be very careful. Now restart the computer press f10 when the F10=ROM-based setup is displayed on the screen. Select File=Restore default and then press enter/ok (if any hassles still come back). cheers
Dec 09, 2009 | HP Pavilion dv6000z Notebook
Trying to fix this kind of notebook, seems that it won't boot, gets stuck in the first screen where the manufacturer logo is showing that it's F10 based rom, Tried to boot from athe cd drive , but ther's...
in the setup utility, make sure the boot sequence is set to check the cd drive and then the hard drive in that order. hit f10 to save your settings and reboot. if your hd section is grayed out, then the system isn't seeing the hdd and it's probably bad.
Oct 03, 2009 | HP Compaq nc6120 Notebook
I have this lessage on start up: F10= rom based setup
its common.it always come and still if it doesnt allow you to access ur pc then click f10 and then run system in safe mode.
Jun 18, 2009 | HP NC8000: NC8000 Pentium M 1.7GHZ, 512MB...
Pressed F10 then Blank Screen on HP Compaq EVO N800c laptop
no F11 is not cmos reset...its recovery....remove ac adapter and battery and press hold the power for 30 seconds and plugin ac adapter and turn on notebook.
Please vote.
Jun 12, 2009 | Computers & Internet
Acer aspire blue screen appeared went off now laptop starts up for few seconds then turns off again, but always a black screen hear the fan a few seconds but nothing
Try this:
  • check to make sure the fan is actually spinning and that there is no debri (dust bunnies) causing it to overheat.
  • Make sure there is nothing preventing airflow, you may need to tilt the back up to allow more airflow
Is there any display at all? Do you see a BIOS splash screen? Do you hear a beep shortly after powering on?
--if you have a splash screen, go into BIOS setup by pressing a button (del,F1,F10...whatever) then set it factory defaults and save changes
--also try removing anything that's detachable (USB, cards, dvd-rom, RAM, Battery...) Hold down the power button for 20 secs then plug in only the A/C and see if you get a bios screen
Hope this helps
Jun 10, 2009 | Acer Aspire 5100 Notebook
When I turn on the laptop sometimes the screen doesn't come up and when it does come up it says F10=ROM Based Setup. When I press F10 nothing happens.
Sounds like the hard disk is not able to boot the laptop.
ROM based setup means you need to reset or reconfigure the BIOS.
Assuming the BIOS battery is OK.
This could be because the hard disk itself died, you can remove the disk and attach it to a USB adapter (cheap to purchase) then connect it to another PC. If you can read the disk OK in another PC then you have a motherboard problem.
Apr 18, 2009 | HP Compaq nc6120 Notebook
HP Compaq nx6125 Notebook Logo
5,892 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
