Candy 24 in. CD623 Free-standing Dishwasher
Problem for Candy 24 in. CD623 Free-standing Dishwasher
The Condensor connected at the power supply point of my Candy Dis
By cyrilmundy on Jan 26, 2009
Dishwasher has burnt out. I need to know the rating iof the condensor
Comments:
Jan 26, 2009
- Is the burnt out item a suppressor perhaps?
Jan 26, 2009
- The suppressor?? is burnt out and shorting, the machine throws the earth trip if it is plugged in.
Jan 27, 2009
- Thanks for the ideas. The suppressor (or is it a condensor) is burnt out. The plastic coating is bunt through with the electonics visible. I have removed the piece which was connected to both the neutral and live. I have not tried plugging the dis#hwasher in after disconnectiong the item. The item does noit have any reference numbers or any details on it. If it is only a suppressor I guess I could try using he dishwasher without it. I would rather not though.
Jan 27, 2009
- THE ITEM IS A CYLINDER WITH CONNECTIONS AT ONE END. IT IS ABOUT 3 CMS LONG, 1 CM IN DIAMETER, . IT IS GREY PLASTIC COATED. IT WAS CONNECTED AT THE POINT THE POWER ENTERD THE DISHWASHER.
Best Solution
posted on Jan 26, 2009
Helpful)
Maintunivers
Rank: Wiz
Rating: 89%, 21 votes
Their is not condensor on a dish-washer?
Do you hear a humming noise? Do you mean your motor? Have your tried rotating the motor fan blades to unjam the motor?
Comments:
Jan 26, 2009
- What is happening with your dishwasher when you start turn it on?
Jan 27, 2009
- There is no compressor in a dishwasher (Only refrigerators)
If your dishwasher is tripping your circuit breaker in your home; with the breaker in the off position ensuring you asolutely have no power; I would remove the dishwasher access panel below (4 screws) and check to see for any "shorting" of the power supply-line wiring that connects to the dishwasher.
I would also check and unjam your motor by rotating your dishwashers motor-shaft. Directions: Removing the bottom access panel and insert your hand and grab the motor fan blades (rear of motor - between waterpump and front of motor) and rotate in a circular motion. * Caution: please ensure you are doing this with the power off and no rings or jewelry on your hands.
Also, do you see any cuts or shorting of your heating element located on the inside; bottom of the dishwasher? (Metal tubing at inside bottom of the dishwasher)
Jan 27, 2009
- Their is no such things as a compressor or condensor on a dish-washer. The main components of a dishwasher is a Motor, Pump, Inlet Water-Valve, Drain Solenoid, Spindal Tower, Heating Coil/Element, Timer Control, etc.
Do not use your dishwasher without having everything connected. I am not sure what you removed. Can you please describe the part, size, etc. and where you removed it from further.
Was this helpful?
Yes
No
Popular Solutions for Candy 24 in. CD623
Questions and Unsolved Problems for Candy 24 in. CD623
Do you recommend Candy 24 in. CD623 Free-standing Dishwasher?
Answer
Answer
Dishwasher makes cracking sound and blows trip fuse, have cleaned pipes in sink and still it... (More)
Answer
open catch has gone floppy small spring has come off and I can't see where it goes
Answer
my dishwasher leaks from the door, but the seal is not broken
Answer
candy 623 dial stops during cycle and no heat at end to dry?
Answer
candy cd623. water left in bottom of dishwasher after cycle, does not drain.dishes are clean. workrd... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
