Hello, i have a haier HSU-09HG04 Split Air conditioner system. It is a fantastic air conditioner. I am needing to move it to another location. While unscrewing I noticed that gas began to escape from the join. I w643d 352e t6 2n6w h6w t6 t4rn 6ff the gas so that I can unscrew both pipes? I hope that you are able to assist. I look forward to your reply? Many thanks Greg
  • 334 Answers
You cant "turn off the gas" in an AC system.
It is a recirculating loop of refrigerant. It is not a gas that's piped in from an outside source.
If you were able to re tighten the nut and prevent any more loss of refrigerant then it is possible to shut off the valve coming from the compressor, (known as the liquid line or high pressure side) while running the compressor, then when your gauges tell you that the compressor has force pumped all the refrigerant into the condenser, you can shut off the inlet side valve, (known as the vapor line or low pressure side) trapping all the refrigerant in the condenser.
Still you aren't shutting it off, you are simply moving all into the condenser.
By the way. it is highly illegal to release refrigerant into the atmosphere and can result in quite hefty fines if caught.
The EPA also requires that anyone dealing with R22, R410 or basically any other refrigerant (freon) have a certification from the EPA before doing so.
You also cannot purchase those refrigerants without the certification.
The only exception being R134A, that does not require the certification. (automotive refrigerant)
Also know that you cannot mix refrigerant types.
It will damage your system, void the warranty, and also is illegal.
With residential systems the different refrigerants can have drastically different pressures and temperatures. Whereas automotive systems using either R12 or R134A are relatively the same pressures and temps.
I said all that to say this.
You REALLY need a professionals assistance here.
Inevitably, you will have to have it anyway as since you cannot buy refrigerant without the certification, you have already lost some of the charge now, and possibly all of it, so it will have to be recharged in order to operate properly/at all.
You will have to have someone with the certification to do that work and get the refrigerant.
If by chance all the refrigerant has already leaked out, then you can certainly disconnect and move the unit. However, it is extremely important that no water or dirt get into the system through those pipes.
Even one grain of sand will cause restrictions and prevent proper operation.
I know this isn't the answer you were hoping for, but I must tell you the truth or I would be doing you wrong and cause the destruction of your unit.
If you want to save money, have a professional come and recover the refrigerant, disconnect the lines, and then when you have done all the other work, have them reinstall the lines, pull a vacuum on the system, and then recharge the system with the proper refrigerant.
Posted on Jan 26, 2009
I have a Haier split type room air conditioner HSU-30HEA03/R2(DB) when I turn it on the display shows E7 what does this mean please.
that mean Communication fault between indoor and
outdoor units. Some wire is cut. check wires from indoor to out door unit. Open indoor unit and check cleme open outdoor unit and check it too
Nov 24, 2017 | Haier Heating & Cooling
Haier Split Air Conditioner Outdoor unit not working
Check or replace the run capacitor for the compressor.
If that is good, or replacing it does not help, try what we in the industry call a "Hard Start Kit".
No matter if that works or fails, (The hard start kit), call the warranty center or where you purchased the unit.
Jul 13, 2014 | Heating & Cooling
I have haier split air condition Hsu 18ck03 When power supply off and comes back i manually switch on from remote.i want it auto on
Your air conditioner is not a inverter model(your model is it a low cost model )and doesn-t work automaticlly when the power is off
Aug 01, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Haier ac remote mod no hsu-18dx
MY HSU - 18 DX REMOTE IS NOT WORKING HOW TO SETUP UNIVERSAL REMOTE
May 23, 2012 | Haier Heating & Cooling
Want to turn off Auto-restart function of haier split ac
I do not know anything about this but from a manual I have seen its tied in with Timer and Sleep functions there are a lot of instruction manuals ou on the web but you description is to generic you need a model number of which there are a lot.
HSU-09LEK13/R2(DB)
HSU-12LEK13/R2(DB)
HSU-18LEK13/R2(DB)
HSU-24LEK13/R2(DB)
HSU-09LEK03/R2(DB)
HSU-12LEK03/R2(DB)
HSU-12CKAS(R2DB)
HSU-18CKAS(R2DB)
HSU-12HKAG(R2DB)
HSU-18HKAG(R2DB)
Just a sample look for a number on the device which may be under a cover.
As its software controlled they do need to reset themselves as to how long this takes varies from machine to machine.
Hope this helps
Apr 05, 2012 | Heating & Cooling
HO UN CONDIZIONATORE HAIER HSU-12RU03/R2,NON FUNZIONA E MI COMPARE SUL DISPLAY LA SCRITTA F22,QUAL E' IL PROBLEMA?CONFIDO IN UNA SUA RISPOSTA RISOLUTIVA.
Purtroppo, Haier non include dei codici di errore nei loro manuali proprietari. L'unico modo per scoprire che cosa significa il codice e la solutuion ad esso ? chiamare Haier clienti Sevice 1-877-337-3639
Aug 25, 2011 | Haier hwr10xc6 Air Conditioner
I speak english and have a room in Spain with a HSU -09ek031r2-1 and can not figure out the remote control.how to get HEAT?!
Push the button that says mucho caliente. LOL or just try translating the remote on google translator
Feb 08, 2011 | Haier hwr10xc6 Air Conditioner
I have a Haier split airconditioner HSU-22HD03, it runs for 5 minutes and then switches off and the power and timer light start flashing.
It shows your indoor PCB faulty. (As you didn't mention any error code). Next time count the green light flashing and write.Thanks.
Jan 11, 2011 | Haier Heating & Cooling
LOOKING FOR ELECTRICAL DIAGRAM AND OPS MANUAL FOR HAIER HSU-22VCA MINI SPLIT
I cant find the manual but I can help you this the issue you might be having. Let me know. http://www.myminisplit.com
May 14, 2010 | Haier HSU22VCA 22000 BTU Cooling Only Mini...
Heating & Cooling Logo
154 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
