Question about Sony PS-LX250H Turntable
Drive belt size for sony PSLX231 - Sony PS-LX250H Turntable
NEED A SMALL DRIVE BELT FOR SONY CDP-CX455.
if you have the old belt, take it to ace hardware and get an o-ring the same size. it will work just as well.
Feb 12, 2014 | Sony MegaStorage CDP-CX455 400-Disc CD...
What is the drive belt number for the sony cdp cx 355? and do you sell it?
take the broken belt to your local ace hardware and get an o-ring the same size. Should work ok for a fraction of the cost of ordering the oem belt.
Feb 01, 2013 | Audio Players & Recorders
Both drive belts are broken. I need to buy the belts. Model # CDP-CX335.
Easier to buy the belts by "size" but there are several parts suppliers on line can sell
you them by the model # !
Apr 26, 2011 | Sony CDP-CX300 CD Player
Sony casette recorder model cfd-8 drivebelts- require a pair of new drive belts, old belts streched hence new ones required
They don't appear to list the belts as a part.
http://www.encompassparts.com/models/?SONCFD8
If you can take them out and measure the overall diameter and cross section (square, round etc & size) I'll see what I can find.
Apr 19, 2011 | Sony Audio Players & Recorders
My Sony CFD-S250 tape drive belts are brittled. Do you have the actual sizes if them. They measyred about 5 to 5.5 inches while they are too loose.
The original Sony belts have been discontinued so sizing will have to be done off the originals. I usually allow for about 3% stretch. But accuracy is important when dealing with belts this small. The difference between 5 inches and 5.5 inches is 10% of the overall length and can be a deal breaker. Also, the thickness of the belt must be measured before matching to an aftermarket belt. A little more and more accurate info will be needed to see this one through.
Nov 27, 2010 | Sony CFD-S250 Radio/Cassette/CD Boombox
I need a drive belt for Sony tape-cd player #CFD-17
All you need to do is measure the diameter and thickness, then enter the details into google, just start with the diameter you can then elimanate the wrong size (thickness) later. IE enter: 60mm Drive Belt.
Jan 04, 2010 | Sony CASSETTE DECK Single Dual Cassette...
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
What is the size of the drive belt?
I would suggest removing the old drive belt and taking it with you to me matched up at the parts store. Depending on the size of the mower the drive belts can be different sizes. For Instance, I have a Murray 40" cut. The drive belt for the particular mower is 94". But if you have a larger mower the drive belt can be larger.
Aug 22, 2009 | Garden
Sony CDP-CX300 How To Replace Drive Belts?
The Sony call center says the two belts are the same size. Supposedly, there is a third belt "under the motor board" but I have not been able to find it. That is the 42x1.2 (4219362601). The two easy ones to replace are 421606101 and only cost 1.95 from Sony.
Aug 08, 2009 | Sony Audio Players & Recorders
I have a sony shelf system with combination cd and cassette - bel
Sorry, we have no belt listing for your specific model, but we do likely have what you need........
If you still have the old belt intact:
> Lay it out flat on the table
> Pinch it at both ends & straighten the belt but don't stretch it.
> Measure the length & then double it and choose or we will recommend
a size about 3-5% smaller.
Old belt too far gone to measure:
> Just use a piece of string and thread it temporarily in place of where the belt goes.
> Then measure the length of the string and Email us the exact length (inches). Along with your EXACT model number.
If your belt has a round or square cross section, please give us the thickness as well. We can assist
you in choosing a belt usually 3-5% smaller than the length you measured.
....from the turntableneedles.com site
Jan 18, 2009 | Sony CASSETTE DECK Single Dual Cassette...
Sony PS-LX250H Turntable Logo
49 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
