Question about ViewSonic VX910 19" LCD Monitor
Iimj9 sonic tft - lcd monitor goes out after 3 seconds
When i push it on it gives good picture and after + - 3 seconds he fals out (no picture anymore)
i see nothing abnormal on the elco's i have the same problem monitor comes on for a couple seconds then goes black viewsonic model vvx910 . does anyone have answer way and can i fix it?
  • 1 more comment
  • patrolunit_9 Jan 26, 2009
    That didn't solve the problem had the monitor disconnected most of the day while I had a replacement on the computer and when I tried the bad monitor again it still did the same thing.
  • dana1957 Feb 12, 2009
    I have the same problem? Any solutions?
  • Anonymous Mar 02, 2009
    IL MONITOR SI SPEGNE DOPO CIRCA 3 SECONDI
    Problem Solver:
  • 9 Answers
You should remove power for a few min then hook up and try again.electronics sometimes need to be reset after any fluctuation in power. Good Luck
Posted on Jan 26, 2009
My lcd is hpl1908w its display goes of 5 minutes on first starup and when its displays goes off i on and off the monitor display comes for fews seconds and then goes off again lcd light is green but...
well if your lcd has no bulge capacitors test your tft lamp both top & down of the screen( particularly top) with spare tft lamp. or use another screen to test it. secondly, test the c5607 transistors in the inverter section but if you know how to use spare tft lamp very well , you will easily detect between your screen & the inverter
Aug 06, 2015 | HP L1908W 19" LCD Monitor
Screen goes black for 4-5 seconds then comes back on
Go into the Catalyst Control Center and check "reduce DVI frequency on high-res displays" and leave "Alternate DVI operational mode" checked. This should resolve it. It is because of your video card that this problem is occurring. Let me know if you need additional help or if this doesn't fix your problem. Good Luck.
Mar 29, 2008 | Acer AL2016 W 20" TFT LCD Monitor
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
Pc and monitor turn on, monitor goes off after few seconds
Please don't get advise from India, this model has a known "Inverter" problem. Order a new one on ebay, and replace it... Problem solved!!
Sep 24, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Screen comes on for less than one second & then goes black.
Possibly  your monitor inverter is broken, have a good look in some angel if the screen shows any picture if so then your inverter is broken. Its a common think with monitors.
Jul 20, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Sound on the View Sonic Monitor
Yes, they are on the front of the screen. There should be a volume up and down button right on the front (usually to the left of the power). If there isn't a separate up and down, try the Menu or 1 and 2 buttons.
Aug 18, 2008 | ViewSonic 19.0" VG910B 1280X1024 TFT LCD...
MONITOR HP L 1940 TFT
I jammed my auto button and the screen now stays on!
Jul 25, 2008 | HP L1940T 19" LCD Monitor
Blank after 2 seconds
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Jun 14, 2007 | Dell UltraSharp 1703FP Flat panel TFT 17"...
ViewSonic VX910 19" LCD Monitor Logo
431 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
