Question about Samsung SCX 4200 All-In-One Laser Printer
Ricoh FX16 open heat error
Hi we have a Ricoh Aficio FX16 with a message error:
open heat error. Cannot print anything anymore!
I read on internet that it's related with the fuser. But do you have more detail how to fix and do you have the parts?
regards
Richard
  • Anonymous Feb 10, 2009
    Hi Thank you for your reply! I took out the fuser Samsung JC9602813A Fuser 220Vbefore received your anwser... I took my ohm meter and I check the circuit was open. on the top it's a thermal fuse
    PW-2N 8274 E150 it was open I took out and tried by bypassing this Pw2nwith a wired fuse...Well as soon I connect I didn't have the alarm OpenHeat Error anymore but almost immediately have heat smell and an alarmOver Heat!!! so I immediately disconnect the unit!! So from no heatingto over heating... !! ( I will like to know if this PW2N act asthermostat (contact close when is cold and when optain temperature openand clos again when could down and so on?) ?
    If it's the case just replace this smal thermal fuse
    PW-2N 8274 E150
    Do you have in stock? and how much? ( it's 220 volt )
    Or it's maybe just a thermal fuser protecter and when it's blow need toreplace. If it's the case it's probably the thermostat who is faultivebut where it is? what it's look like? do you have in stock and how much?
    I was thinking to replace the fuser unit assembly but I read that thiskind of problem can be from a defect module card!! so now I am moreconfuse!
    Do you have
    Samsung JC9602813A Fuser 220V ( it's important
    To be a 220Volt!! )
    and how much it is?
    Again I very appreciate for your help
    Regards
    Richard
  • 679 Answers
The Open Heat error indicates that the sensing circuitry for the fuser has detected that the fuser is not heating up. This can occur because either the sensing circuitry isn't detecting correctly or the fuser actually isn't heating up. Probably the latter in most cases.
How to fixya? Probably install a new fuser and you'll be fixed. Want to be sure before you spend $$ ?? Pull the fuser out. You will see a wiring hookup with two heavy wires that supply 110V to the heating lapm. Connect an ohm meter across the two wires that are on the FUSER. A good fuser will read around (0) ohms - complete circuit. A fuser with a bad lamp or a bad thermostat will read infinite resistance (open circuit).
The thermostat is probably available as a separate item. It's probably about $15 from several online sources. I believe you will need a JC47-00013A. I could be wrong. You'll need to do some research if you find that to be the problem.
Posted on Feb 09, 2009
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Ricoh Aficio 2232C Error Message SC393-02
I had the same problem after transit of copier. Try removing the yellow developer unit and give it a good shake. You may need to do it with the other units too.
Apr 16, 2013 | Ricoh Aficio 2232C Color Copier
My printer Ricoh aficio cl3500n does not print and all the lights on. Why?
The first step is to turn the machine off and then turn it back on. Do all the lights come right back on, or is it okay until you try to print to it?
If all the lights are on, there should be an error message appearing on the display. It might say out of paper, or out of toner, or a cover open, or it might show a code (such as "sc 501").
What is the code or error message that appears?
Jul 09, 2010 | Ricoh Aficio CL3500N Laser Printer
Smoke
well this is really dangerous...this shows a power problem with the printer...so better let the device cool down and change its location before printing
Jun 07, 2010 | Ricoh Aficio FX10 Fax Laser Printer
Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Apr 20, 2009 | Ricoh Aficio SP C210 Laser Printer
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
Error message replace/ supply
If you open an internet connection and an the top address bar type in the IP address you will see you printer and be able to see the supply that needs changing
Jan 05, 2009 | Ricoh Aficio CL3500N Laser Printer
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Nov 11, 2007 | Ricoh Aficio SP C811DN-DL Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
950 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
