Question about Electrical Supplies
Did I break my dimmer knob?
I have an old rotary dimmer knob (not sure which kind). I didn't know that the knobs just pull off, so I tried to push in and twist. The light turned off, but now it won't turn back on. Should I just replace it?
  • 2,113 Answers
You can get the knobs separately if you look. First check if the knob was a half circle or a serrated style, i think the replacements have an adapter to fit either style.
Posted on Nov 21, 2013
  • 122 Answers
SOURCE: humming inside the switch
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
Posted on Nov 23, 2008
  • 22 Answers
SOURCE: replace dimmer switch with toggle
Both wires should be black because the switch interrupts or breaks the connection to the light. It doesn't matter which black wire goes where. Just be sure the power is OFF and then undo the dimmer switch (usually has wire nuts connecting the black leads) and then connect the wires to the new toggle switch.
Turn on the power and feel good about your work!
Posted on Jul 24, 2009
VtToolMan
  • 704 Answers
SOURCE: wiring dimmer to knob and tube
You should attach the green grounding wire to the metal box using a green grounding screw. You don't want to leave the wire loose, as any contact with the switch screws could cause a short.
Also, you should wrap the switch with at least 2-3 complete wraps of electrical tape to prevent the screws from contacting the sides of the wall box.
As a side note, you should likely have a complete check done on your house if you still have knob and tube wiring installed, as the dangers associated with this very old wiring are many. Typically, older K&T wiring was used in homes well over 60 years ago and houses then only had minimal electric current drawing devices, such as lights and a couple of other small appliance devices (toasters, coffee pot, TV and radio, etc.)
The problem with older homes with K&T wiring still in use, is that the circuits can be easily overloaded with modern electric convinences and lead to a possible fire situation, especially since there is no dedicated ground to help mitigate short circuits, etc. Also, the rubber based insulation used on this type of wiring deteriorates after 40 years (+/-) and rodents tend to chew on exposed wires in attics and crawl spaces.
I don't wish to alarm anyone, but as a Licensed Master Electrician, I've seen and done my share of repair work involving Knob & Tube wiring and even had a couple of homes that had a mix of it and other, newer wiring, that I've completely rewired. Many states require K&N wiring be replaced before a home can be sold, so getting a jump on it will make your home safer and better suited to operate all the devices that people tend to have, in today's society.
Hope you find this Very Helpful and best regards!
Posted on Sep 10, 2009
  • 107 Answers
SOURCE: Lutron Glyder Slide Dimmer GL-603P (new dimmer
Sadly, yes, it just sounds like the switch got stuck. You should be able to yank that knob off and try to manually unlatch it with something thin and long (like a pencil) - just, do me a favor, and make sure whatever you use isn't conductive, there shouldn't be any exposed electrically, but just be safe about it.
If that doesn't work, call their tech support center at 1-800-523-9466 - they will most likely replace it for you.
Posted on Oct 13, 2010
SOURCE: My rotary dimmer doesn't switch 3-ways. I have to
You posted under Leviton rotary dimmer.
Lutron and Leviton have many 3-way dimmer styles, and both make 3-way rotary dimmers.
I remember years ago replacing 3-way switches with dimmers and having same experience as you. One dimmer has to be ON for the other dimmer to dim.
Later I learned when you replace both 3-way switches with dimmers, you buy a control-and-companion dimmer set. One dimmer is main, and it lets you dim from both locations. The two dimmers communicate with each other electronically. Buy these dimmers at lighting store that specializes in fixtures and dimmers. Ask for most experienced salesperson.
I checked to see if rotary dimmers are made in the companion set. And neither Leviton or Lutron show 3-way companion set rotary dimmers.
1) Leviton spec sheet on rotary 3-way dimmers does not show companion dimmer. This indicates that Leviton rotary dimmers don't have capability of communicating with each other.
2) Lutron has image of 3-way rotary dimmers.
Image shows single rotary dimmer in 3-way & 4-way circuit.
This tells me that Lutron does not have companion dimmer for 3-way rotary dimmer.
Posted on Dec 01, 2010
Bosch rotary hammer will not rotate
Need more information to accurately help you - model#.
The easiest thing to check is possibly a broken selector knob - most Bosch selectors come off by pushing the red button in further than normal & turning clockwise (some however are counter-clockwise) further than it normally goes - knob will pull straight out. Inspect the pin on the knob & the receiver in the tool. If these appear OK you could be looking at a bad clutch gear or stripped crown gear depending on the model
Oct 04, 2014 | Drills
Knob falling off
More details are needed. If it is a rotary dimmer you can possibly spread the shaft tines a bit if it has them or find the clip that was holding the know on. Hot melt glue placed in the knob first then pressed on the shaft may work. Just do not over fill the hole.
Jan 29, 2014 | Schlage Electrical Supplies
I need a wiring diagram to wire two way dimmer switched in place of normal switches
Take off the 2 wires from the old switch... put on the 2 wires from the dimmer. the 3rd wire is a ground it is green put it on a ground screw at the back. If your switch has more wires it is likely a 3 way system and needs a 3 way switch instead.
Apr 04, 2013 | Cooper Wiring Devices 6009W-K ROTARY...
95 Toyota Celica ST Dimmer Switch
The instrument dimmer function is most likely in the light switch. Pull the switch to turn the parking lights on. Then rotate the knob to bring the instrument lights on, continue rotation of the knob to bring the dome light on. Be sure to turn dome light off so as not to kill your battery. the dome light will not turn itself off.
May 08, 2017 | Cars & Trucks
How to replace knob assembly on bosh 1 1/8 rotary hammer drill 11222 evs
Push the red button all the way in as far as it goes and turn the knob to the left (counter clockwise) past it's normal position. Then you can pull the knob out. When you replace it make sure that the pin part fits inside the slot of the shifting arm inside the tool.
Aug 07, 2012 | Bosch Drills
Burner stays on,after turning off
you could have a bad switch behind the knob or the knob isn't turning it off,pull off the knob and see if the metal clip that holds the knob on tight didn't slide up on the shaft,if it did pull it off with a needlenose plyers and stick it back into the knob,next time send the model number and if it's gas or electric
Jul 08, 2011 | Kitchen Ranges
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
Rotary dimmer turns but won't click on? It was working up until half an hour ago. It just trns and turns. The light is off
probably the plastic knob is stripped out. pull it off and see if you can turn the dimmer by hand.. if so get a new knob.
Dec 28, 2009 | Electrical Supplies
Wiring dimmer to knob and tube
Aug 27, 2009 | Cooper Wiring Devices 6009W-K ROTARY...
Replace dimmer switch with toggle
Jul 24, 2009 | Cooper Wiring Devices 6009W-K ROTARY...
Electrical Supplies Logo
94 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
