Question about Lowrance Boating
Wire pinout for X55a
Looking for the power pinout for an Lowrance X55a fish finder. Part no longer available and mine was destroyed.
ward_knutson
  • 64 Answers
SOURCE: i need a manual for humminbird wide 100 fish finder
You can find the manual you need at: http://www.humminbird.com/support/FAQ.aspx?faqid=72
It is listed in the legacy products area with the wide series of units.
Posted on Nov 26, 2008
  • 106 Answers
SOURCE: i bought a fish finder from harbor freight and it
http://www.harborfreight.com/manuals/94000-94999/94511.pdf
Your welcome!
Posted on Jun 04, 2009
Editor925
  • 285 Answers
SOURCE: CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Posted on Jun 15, 2009
  • 30 Answers
SOURCE: How do you get the fish to show up on the screen
Are you looking for the little fish symbols?
Press MENU, down arrow to SONAR FEATURES and press ENT. Arrow to FISH SYMBOLS and press ENT. Press EXIT twice. Any significant return in the water will now show up as a fish symbol.
Are you looking for the fish arches?
You won't get any arches unless the boat is moving and of course there are fish passing within the transducers signal. The shallower the water, the less area you are covering and less likely to get a fish return.
There is an OK guide to understanding what you see on the sonar screen at the link below. It if pretty technical but parts of it may help you out.
http://primus.lowrance.com/support/resultDisplay.do?gotoLink=5&docType=1000&contextId=351%3A5.47%2C11918.11930%2C22.47&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FSonar&contentId=9de88fa2-0b60-4b44-a470-29ee14767b3e&responseId=135ccbe2cfd4f608%3A1fe88d%3A122773df7e0%3A7c2&groupId=4&answerGroup=1&score=981&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FSonar%2FChart+Tutorial.htm&result=0&excerpt=Chart+Tutorial+Deciphering+Sonar+Charts.&question=chart+tutorial&resultType=5000#Goto5
An X96 owners manual can be downloaded from http://www.lowrance.com/en/Downloads/Manuals/
Posted on Jul 14, 2009
SOURCE: uniden ff 3300 fish finder
I have an operators book because i have that system my self. Mine will not lock on to satelites. I want it looked at and repaired but don't know who to send it to.
Posted on Aug 17, 2009
Wiring to elete7 Lowrance fish finder
Yes you must wire it Arthur :-) You realise you have no question just a statement?
Wire it direct to the battery via an inline fuse. If you have two batteries don't wire it to the starter battery, use the Auxillary. If you check the Lowrance site there will almost certainly be installation instructions. I am a Humminbird guy. I am sure there is a Lowrance Facebook page with lots of knowledgeable people. The Humminbird one is very good.
Mar 06, 2016 | Lowrance Boating
It was staying on for about 6 hours then a blank screen. now it comes on to the startup screen and then goes to blank screen.
Same thing happened to my older model. Going to research it today. Mine was on a hot day and Matt have over heated. After recharging the battery it no longer comes on at all. Let me know what you find out if anything
Sep 14, 2015 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
The diagram for the fish finder has two cables for power. does each cable have a wire going to a hot lead and a groundand a bond or do you just need to connect only one wire
Hi
One of the two cables is for power to the battery while the other supplies power to the transducer. BOTH cables (+ and -) must be used and intact.
In case anyone requires it, here is the link to the installation manual.
Hope this helps.
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/GB/ELITE-4_HDI_OM_EN_988-10576-001_w.pdf
Feb 28, 2015 | Lowrance Elite-4x Fishfinder
Where do I get a manual for lowrance elite 5 fish finder chart plotter gps
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
Nov 23, 2014 | Lowrance Elite5x Color Fish Finder 102001
Lowrance Elite 4X fish finder that reads between 1.5' and 2.5'
Hey Anon
The transducer installation is more important than anything.. next to correct wiring! You must make sure the mounting is good,,, if its outside the hull, make sure its sitting 1/16th below the hull with no obstructions.. if its inside the hull, the medium you used to fix the puck to the hull must be porosity free and the puck sitting as level with the WATER as possible..
Now, take the manual to the lake with you and DO NOTHING but read the manual and apply what you read to the unit,,, read -repeat - read-repeat.. forget about fishing... now read-repeat and learn... IF nothing seems to be reading correctly.. its probably the transducer installation.. YOU DID use a/the transducer specifically for this unit!!
Jun 24, 2017 | Lowrance Elite-4x Fishfinder
Lowrance 112c gps shuts off when cranking main engine?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} This is very common when using a single battery system in you boat.
If you more then battery connect the fish finder to the second battery.
Or if the Depth finder is connected through the acc. on the boat. The power is being cut off be fore the starter is engaged. By pass this and connect through a correct size fuse.
May 08, 2009 | Lowrance Lcx 112c 10.4" Gps Fish Finder...
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Boating Logo
54 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
