Question about Crosley CDE6000 Electric Dryer
My belt came off my dryer, Help!
My Electric Crosley Dryer was squilling b/c of the little turning wheel, & while i was fixing that, my belt came off the little pullies. Does anyone know how to fix this, or have a picture of what it shold look like?
  • Anonymous Jan 03, 2008
    im trying to change the belt and forgot how it goes back on
    i have replaced my belt and forgot how it goes back on !!!
    Sergeant:
  • 274 Answers
You should have a "tension pulley" that the belt goes around somewhere in the belt track. Usually a "wheel or pulley mounted on a spring" which looks like a flat piece if metal. Check to see if it has come out of its positon or the flat spring has broken. You can buy replacements if it has. Simply reposition the belt and push the tension pulley in such a way as to engage the belt correctly. That should fix it.
Posted on Jul 16, 2007
SOURCE:
Drum turns very little
Sounds like you have a belt that is one size too big
Jan 08, 2013 | Crosley CDE6000 Electric Dryer
Dryer was running and then just stopped has power it is not hot just wont start again how do I fix this.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 26, 2011 | Crosley CDE6000 Electric Dryer
Dryer wont turn on
heatman101
Jul 11, 2011 | Crosley CDE6000 Electric Dryer
My Crosley electric dryer will not turn on at all.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Apr 18, 2011 | Crosley CDE6000 Electric Dryer
Crosley dryer model # cde22b6v. Timer switch works but dryer will not turn or heat. I checked connections. Belt is good. Motor turns free. What do you think I need to check?
door switch, bypass by taping the wires together. here are some other things to check:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 30, 2011 | Crosley CDE6000 Electric Dryer
Dryer does not turn on
heatman101
Oct 10, 2010 | Crosley CDE6000 Electric Dryer
Crosley cde6000w. was running fine, quit while drying clothes. machine was very warm to touch. still had power to control knob, buzzed when turn knob to end of cycle. let machine cool down and still will...
heatman101
Sep 17, 2010 | Crosley CDE6000 Electric Dryer
My crosley dryer will not start when pushed, the timer starts, but no power to start dryer
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 11, 2009 | Crosley CDE6000 Electric Dryer
Crosley dryer..it squeeked we oiled the pullys
Did it smell like burnt rubber or maybe plastic burning? After you try to run it for about 10 seconds (and it won't run) then you touch the motor (with the dryer unplugged) it is hot?
It sounds like the brushes could be dirty due to the lag you placed on the dryer when it was installed incorrectly possibly.
OR
While it is plugged in, are the lights coming on in the dryer when you open it?
It could be a fuse if it has no electric going to it (the light does not turn on)
OR
Will the drum spin if you attempt to turn it manually?
THe pulley or another item on the belt system could have burned (ruined) when it was installed incorrectly.
Try to walk through each piece of the system that was affected by teh incorrect installation and see if there may be an item that is not working correctly; this could be an easy fix.
Hope this helps
Sep 06, 2009 | Crosley CDE6000 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
164 people viewed this question
Top Crosley Dryers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Steve Allison
Steve Allison
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
