Question about Hampton Bay Dryers
Hampton bay brookedale II celing fan remote stopped working
First the remote stopped working, which stopped us from using the lights on the fan, now the fan seems to run slower, even stop at times. We can't adjust the speed of the fan, maybe the remote receiver is bad? The fan is only two years old, this problem has been going on for at least 6 months or so, and getting worse.
SOURCE: Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Posted on May 11, 2008
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
  • 37 Answers
SOURCE: Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Posted on Jan 24, 2009
  • 75 Answers
SOURCE: Hampton Bay 60" Brookedale fan remote not working
The Remote (TRANSMITTER) control AND the RECEIVER must both be set to the same CODE in order for the REMOTE to operate the fan.
!!WARNING!! YOU ARE ABOUT TO ENTER HIGH VOLTAGE ELECTRICITY ZONE!!
The RECEIVER is located in the CANOPY, the part of the fan assembly next to the ceiling which is also called the Hanger Bracket.
At the bottom of the Canopy you will see what looks like a large flat washer. Rotate the washer counter-clock wise to release it.
Then rotate the Canopy counter-clock wise to release and lower it. You will see the RECEIVER, which will have a short antenna at one end, tucked in among the electrical wire and bracket. Simply pull the RECEIVER out and you will see the CODE switches. Remember to set both devices to the same CODE.
Good luck. :)
Posted on Apr 26, 2009
SOURCE: Screaming Maytag dryer
You're probably correct that it's bearings/bushings.
Take the front off by first popping the top. Lubricate all moving parts (mostly bushings/rollers/pulleys on shafts) including the motor shaft/bearings.
Don't get oil in belt path (like on a pulley where the belt will ride) or on the belt.
This should solve the problem.
Use something akin to 3-IN-1 Machine Oil.
Charlie
Posted on Aug 27, 2009
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Do not have a remote
If this is a Hampton Bay fan, you probably can buy a suitable remote from a Hampton Bay dealer...BUT before rushing out to buy a remote, it would be a good idea to find out whether the reason this fan turned up at a yard sale is not that the remote receiver failed
Jan 07, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Bought a ceiling fan with this model number and no remote how do i obtain a remote from Hampton Bay to get my fan going bought it at a yard sale. thank you
you can just go to lowes or home depot they carry them there easy to put in just use two people to place it up works a lot better dont forget turn power off first, good luck
Aug 12, 2011 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Fan doesn't work after nearby lightning strike
Your issue is most likely a faulty speed control, which presumably was destroyed by a power surge. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The fan unit itself is manufactured by AirCool 800-896-4908
Unfortunately the Brookdale fans with a Rhine 7058 series controller have a separate circuit wire for each speed. Rewiring this to use a conventional fan receiver that uses a single wire to control each speed is not easily achieved. Your best bet is to order a new remote receiver of the proper type.
Jun 04, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I HAVE A HAMPTON BAY MODEL AC-418 CEILING FAN. IT
Your issue is most likely a faulty speed control. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
May 10, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Good luck. :)
Apr 19, 2009 | Hampton Bay 04379 Madison Avenue Ceiling...
Jan 09, 2009 | Hampton Bay 52 In. White Redington...
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Aug 25, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Problem with Hampton Bay 54 In. Flemish Pewter Ceiling Fan With Heater
did you check the circuit breaker to see if its tripped?im assuming the voltage rating of the wires your decribing are 110 volts and the fan likewise.the white wire could possibly be a neutral wire,meaning you should hook up the red and black wire.let me know
Jul 30, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Dryers Logo
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
