Question about HP Compaq nx6310 Notebook
No Hard Disc found after crash
I installed a few new programms and couldn´t start the computer again after that. so forced by "half knowledge" i tried a few things (sanitizer, reset the computer) but nothing works. if i try to install windows XP again it says no hard drive found and cancel the installation proces. i just can´t install windows again and i havn´t got the recover boot CD :-( so what to do? anybody can help?
  • siesmi Jan 29, 2009
    thanks for the answer..... i tried this but nothing happened if i pressed F1..... at the end i dissabled SATA native mode and could install windows and all drivers, so it´s working now ;-))
    Sergeant:
  • 306 Answers
Compaq uses F10 at boot to initiate the recovery program resident on the hard drive partition normally called "Recovery". If you cannot initiate the hard drive at boot then press F1 to get to setup and see if the hard drive is recognized there. If it is not then you will have to troubleshoot the hard drive.
If you have another laptop to try the hard drive out or a laptop to IDE hard drive adapter  (cheap) to connect to a desktop computer as a slave drive you will either verify that the hard drive is bad or it is good and a boot sector problem is at hand. Also if you can get the drive recognized as a slave drive you can either rescue data or format the drive.
These are preliminary steps so post again when you have more information. Steve Medley
Posted on Jan 26, 2009
  • Stephen Medley
    Stephen Medley Jan 29, 2009
    Thank you for responding as I try to keep track of common oversights with users new to SATA settings and this is one I am beginning to see often. I will add that to my clarifications questions though I suspect that if you had not noticed those settings you may have noted that you had an IDE drive with SATA settings enabled.
    I am happy that you found the issue and remember that whenever these online queries are addressed that you are my only eyes. Here is a link elaborating on what you were dealing with: http://en.wikipedia.org/wiki/Advanced_Ho... regards, Steve Medley
Flashing folder when i turn on mac
Your hard drive may have crashed or it's settings have changed so it is no longer recognized as a startup (boot) drive. Try starting from your original operating system CD. (or borrow one). Press the C button at power up to force your computer to start from the CD.
Once started, don't install the operating system. Go to the pull down menu's and select Disk Utility. If Disk Utility sees your hard drive, select it and run the repair disk program. If it doesn't see it, your hard drive has likely crashed. You will have to replace it, install a new copy of the operating system, and likely have lost all your data and documents. This is where I would start.
Mar 08, 2014 | Apple MacBook Pro Laptop Computer with...
WONT GO BACK TO FACTORY SETTINGS
hard drive posible giving trouble try to replace hard drive then install windows from dvd cd
Mar 02, 2012 | Computers & Internet
Laptop now always starts in safe mode since downloading a game off the internet
Could be a virus, especially if you obtained this from an unreliable source (we have all done it)!
I'd first of all download this little programme, free to home users and very very good.
http://www.freedrweb.com/cureit/?lng=en
Install to a USB pen drive or similar, boot the laptop in safe mode and run it. Once run and any virii found are deleted, run again setting the scan path to C:/.
Check and kill any virii found
Now delete your sytsem restore points ( the viruses if found will be backed up there).
Reboot and you should get into normal boot
If the above fails to fix this, (ie no virii found) the programme you installed has damaged your settings. In which case, first of all, go to MY Computer / Right click on hard drive/ properties / tools and run a disc check on reboot
Reboot and try again
If that fails, you will need to install the OS and do a repair
If THAT fails, you will need to do a full install
Mar 29, 2011 | Toshiba Satellite A135-S2266 Notebook
I cant get my ibook g4 to run it turns on with blinking folder
Blinking ? mark folder means that your OS can't be found. Take out your RAM underneath the keyboard and re-insert and try again. Nothing? Install a different new RAM chip and try again. Nothing? Install your disc 1 install disc, power down, wait a few seconds, now press the power button to turn on, now press and hold the option button, until your disc 1 shows up, select it, and bring your pointer to the right arrow on the screen and press enter. Now your booting from the disc 1. Go to disc utility folder at the top of the screen and select your hard drive and then select repair disc permissions. Then shut down and reboot when finished. Nothing? Your hard drive is fu.k.d-Try re-installing the OS. Nothing? Your hard drive is really fu.k.d-You need a new hard drive. Installing a new hard drive in the iBook is a *****. You may want to pay someone to install a hard drive or you can just get a new laptop.
Mar 09, 2010 | Apple iBook G4 Mac Notebook
My laptop is unable to read external device (disc of photos). Had ability to do so until hard drive crashed whilst still under warranty (no longer under warranty now). The only drives on computer now are...
Make sure that your source disc is compatible with your drive. if it has a dvd, then you can use dvd disc.
Also, try to download and install the DVD/CD driver for your laptop.
Nov 25, 2009 | HP Pavilion DV6700T Notebook
Computer crashes upon rebooting. Then starts back up again to crash again
Your operating system inside the HD(hard disc) drive is virus infected. Take the hard disc drive off from your computer and have it reformatted .
Oct 01, 2009 | Computers & Internet
I have no sound on GEForce 7050M-MV2.0 I run
Need to cross check some points:
-> check if Realtek already installed in Add/remove Programmes ( can be some CMI entry and Broadcom entry)
If yes->
Start Windows in safe mode.
-> Ignore (cancel) all “found new hardware” prompts
-> Uninstall Realtek(CMI) and Broadcom applications from Add/Remove Programmes
Reboot into normal mode… ignore all found new hardware prompts again
run the driver CD again for both.
I Hope it will work.
Jul 30, 2009 | Computers & Internet
HP Compaq nx6310 Notebook Logo
140 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
