Question about Garden
What causes new belt to slip on 2007 polaris ranger 4x4
Changed belt and new belt is slipping drive belt
SOURCE: 1990 polaris trailboss , trans ,or clutch slips in water
Check for wore clutch belt and also check to see if your getting water in the clutch housing. If your getting water in the housing, your clutches could be corroded as well. There should be no water getting in that shroud.
Posted on May 19, 2009
  • 38 Answers
SOURCE: Our 2007 Polaris 500 H.O. seems to be slipping
check you belt
Posted on Oct 01, 2009
  • 207 Answers
SOURCE: polaris transmission
first check ur sprocket and see if ur teeth look skinny if so ur sprocket is probably bad or the chain is bad see if chain feels real loose between the individal links
Posted on Feb 24, 2010
SOURCE: oil change for polaris 325
Drain plug is on the bottom of the crankcase. No need to pull skid plate. Combo fill hole and dipstick is on the lower left hand side of the engine
Don't forget to do the filter at hte same time.
Posted on Sep 05, 2010
  • 15 Answers
SOURCE: have 2001 polaris sportsman 4x4
sounds like your clutch is stuck and wont open up to let belt drop in between pulleys. check both the drive clutch and the driven clutch fo no binding or for smooth operation. that would keep the wheeler in a low gear position
Posted on Jan 06, 2011
2007 polaris ranger 500 efi 4x4 looses all power before key switch
Check the main fuse to the ignition switch.It will either come directly from the battery + terminal or pick up from the "hot" meaning "positive" side of the starter motor relay. If it comes from the relay you will locate it by following the main "positive" lead from the battery. From the relay you can then trace it to the main fuses. Hope this helps you out.
Nov 04, 2016 | Polaris 2007 Ranger 4x4 EFI
1999 Sportsman 335 4x4. Why doesn't it seem "right"?
Make sure it is the recommended size. Can you adjust the tension? Try some belt dressing, it's a spray that makes belts grab better. Good luck!
Feb 29, 2016 | Polaris ATV
2013 POLARIS RANGER 900XP EPS Seems to put itself
im having the same type of issue but with a sportsman 500 but it goes about 5 feet and locks into 4x4 stearing jerks and brings itssel to a stop im thinking electrical or front diff or even transfer case.
Sep 01, 2013 | Polaris 2013 Ranger XP 900
Serpentine belt slipped off while driving ranger in very slushy snow driving conditions. do I need new belt or tensioner
probably both. first check all the pulleys and tensioner. one of them is the cause for the belt to come off. Make sure they are all tight and no wabble.
Nov 17, 2010 | 2000 Ford Ranger SuperCab
2004 sportsman 400 4x4 shifts late and hard going into high end
polaris drives are variable speed. they only have 2 ranges plus reverse. it sounds like either the driven clutch is slipping or the trans is slipping. the gear cogs inside may not be locking in properly and the shifter rods may need adjustment.
May 04, 2010 | Polaris ATV
Change belt on ranger 700
Ihave a 2009 with only 450 km on it and its the worse bike i ever bought ,its alway stuck and now my 4 x4 kept slipping out ,i was told that it was a gear in the front transfer case ,i was told that i didnt need the extended warrenty because those machine are very dependaple wha right
Sep 14, 2009 | Polaris ATV
TRANS. IS SLIPPING
belt is slipping.
Apr 08, 2009 | Polaris ATV
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
