Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Wet screen i windex my screen and widex leaked under the panel into the projector screen now there water spots how do get the screen out to dry and clean it
  • joshua james Jul 16, 2007
    thanks thats what exactly what i needed to do
    President:
  • 3,130 Answers
You will need to take out the screen from the front of the TV set. Then the screen will be taped together, as it is in two pieces. Clean the screens very carefully and do not forget what way you took them apart. It will make a differance as they are simply not plastic, they are each a special lens. Good Luck
Posted on Jul 16, 2007
I have several large water spots on the lower right corner of the tv from overspray with windex. Can this be fixed?
Not a good idea to clean tv with windex. Try wet towel dipped in mild soap solution. Make sure all water has been removed and towel is only wet. When tv off, try removing the spots. Turn tv on only after tv dry.
Dec 22, 2013 | Apex Digital LD4088 LCD TV
I did something wrong.....
Windex is not the best cleaner. Bed and Bath Beyond has a very good NON-Streak class cleaner that I tell my customers to use. The best solution is NOT to Spray directly onto the TV Screen. Remember the glass is only delivering the picture from an RGB projection unit sitting inside the enclosure. It is not the electronic projector and the screen is separate. It can be replaced if damaged; however I believe it is only streaked and needs proper cleansing. If you get the new cleaner, spray the solution onto a soft cloth and wipe the exterior screen. Promptly wipe it dry and if you need to do this a few times, eventually you will get the glass clear and enjoy the show.
Dec 18, 2013 | Panasonic Televison & Video
Back floor wet after it rains
On a dry day take a garden hose and shoot water in any area that could leak and check and see if there is water in any of those areas. Also check under the car to see if there are holes or cracks that could leak. A rust spot will sometimes leak as well.
Jan 12, 2013 | 2009 Saturn Astra XE
While Mitsubishi is off, have spots between inter-projector screen and outer
yes you can disassemble the front screen assembly to clean any spots dont use windex or streaking will result just a damp soft cloth then dry
Jan 02, 2013 | Mitsubishi WD-57733 57" HDTV
I have a 2001 Lincoln Town Car . When it rains, there is water in the passenger
The vent under the hood on passenger side , more than likley the seal is leaking letting the water go inside. I have had to fix my mother's 1999 and my 2001 lincoln. It is not very hard to fix. You will have to remove the screws on the passenger panel under the hood to get to the vent. Pry the vent loose and re seal. You can take the hose and spray water on the W/S when it is dry to make sure it is coming in at that location.
Jun 30, 2011 | 2001 Lincoln Town Car
Spot Bot leaking water from reservoir through brushes
make sure that your collection tank is empty and correctly attached. If it is full, it will shoot water on the spot, but not **** it up several times in the cleaning process leaving a large wet puddle bigger than the original spot.
Mar 16, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
I have a 2001 Ford Mustang with 71,000 miles. My
If you have a wet seat then it is likely defective weather stripping around the window.
Try this. If the floor is dry, then it rains and the floor remains dry, only gets wet after a drive in the rain or on wet streets, you may have a hole somewhere.
Check for holes from missing rubber grommets or holes in the floorboard or firewall from rust. Check for any rust holes or missing rubber grommets under the car or on the firewall, anywhere water can splash up into the vehicle from driving in rain or running through puddles..
Check wet spots along the carpeting all the way up under the dash, if the wet spot is higher than the floor itself, you could be getting the water from splashing through puddles.
Any holes under the car or in the fenderwell even up on the firewall can cause this problem.
First check for any obvious signs of rust, if none are found then look for missing or defective rubber grommets.
Dec 14, 2009 | 2001 Ford Mustang
It seems to be leaking water
Do you know where about's the water is leaking? Have you parked on a dry spot and seen a wet spot the next day? Could be radiator, waterpump seal, or the plastic tubing on the heater core could have broke which is common
Sep 28, 2009 | 2003 Chevrolet Silverado 1500
Samsung LCD screen cleaning technique
Hard crusties? what do you do to have this type of matter on the screen?
Be carful with what you use on the screen, a damp cloth is permissable. This does not mean spraying liquid directly on the screen and wiping it
Spray into the cloth or dampen cloth and wring out well. Do not let any excess water drip down the screen especially if it gets into the TV via the outer frame around the screen.otherwise poof it will never work again
please rate our help to keep the service online
Aug 18, 2009 | Televison & Video
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
94 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
