How to locate vertical output ic on mainboard
I have a sharp tv 32u-s50b.I want to fix it myself.somebody told me that it is the vertical output ic.but I don't know where it is.i have the service manual ,but it does'nt say nothing about that part.Please help
                                                            Thankyou
        Raul
  • 4,234 Answers
This should be a small flat IC attached to a heatsink and will be marked TA8427. I think this one has about 11 pins in it.
Dan
Posted on Jan 26, 2009
How do I adjust the vhold on the sharp 32u-s80? My screen is flipping
[PDF]32US60 Operation Manual - Sharp Electronics
files.sharpusa.com/Downloads/.../tel_man_32US60.pdf
Sharp SolarEvery SHARP Color Television set is tuned and adjusted for proper color and ... serious injury to a child or an adult, and serious damage to the equipment.
SHARP 54GS-61S OPERATION MANUAL Pdf Download.
www.manualslib.com > Brands > Sharp Manuals > CRT TV > 54GS-61S
Sharp operation manual color television 32u-s50b (48 pages) .... view the all functions implemented in your TV set demonstration and set the CHILD LOCK. 1.
SHARP 32JF-77H OPERATION MANUAL Pdf Download.
www.manualslib.com > Brands > Sharp Manuals > TV > 32JF-77H
Dec 21, 2015 | Sharp Televison & Video
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
Dish network code for sharp 32U-S50B
Susan Lantz,
We do have codes to program the remote to your television. I would need the model of remote to provide specific codes, but some codes that have a higher success rate for Sharp are 628, 521, 741.
You can view this link: http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx and enter the information you have to get codes for your specific model to program. If you have any other questions or need further assistance let me know!
Tommy Faust
DISH Network
Oct 16, 2011 | DISH Network IR Remote Control
Only a horizontal line can I see in my TV
In most cases the vertical output IC and possibly a fusible resistor off of the high voltage transformer are bad. The vertical output IC is located on a heat sink and usually right next to the vertical yoke winding connectors that are green and yellow in most sets. Please take a moment to rate my answer..Thanks...
Nov 24, 2009 | Sharp 27G-S60 TV
TV vertical field collpses. Toshiba Model CF2668B.
Very likely it has bad solder connections on the vertical output IC. Or the IC could be bad and needs to be replaced.
Feb 03, 2009 | Toshiba 53H71 53 in. Rear Projection...
Turns on but quickly turns off
hi
you have defective power oscillations! in this model you have to replace the vertical output ic. because the power oscillation for Jungle IC is passing by from Vertical output.
Thanks!
Dec 29, 2008 | Sharp 32U-S60 32" TV
Sharp 32U S50
Maybe a problem in deflection section. If there is a problem in these section the micom ic is trying to protect to continue anymore short circuit. Or there is a leakege in power supply section. This could be fixed by service technician only. Better to call nearby service people.
Jun 24, 2008 | Sharp 32U-S650 32" TV
Sharp 25" tv unknown model (no av in)
It is a simple trouble, tv has got dry solder joints in the vertical deflection circuit. Resolder vertical output ic pins and related components, this will be okay.
Dec 17, 2007 | Sharp 25R-S100 25" TV
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
Tv cuts off 10 seconds after switch on and destroying vertical output ic
If the main IC is not putting out a vertical drive signal then the vertical output will not do anything and therefore will not be damaged. What exactly do you mean by the set "literally eats deflection IC's"? What is the number on the vertical output IC? I will bet that your pump-up cap or pump-up diode is defective.
Jul 03, 2007 | Sharp 27K-S100 TV
Televison & Video Logo
209 people viewed this question
Top Televison & Video Experts
Electro Med Services...
