Question about Euro-Pro Food Processors
Ninja qb900 30 parts
Need gear on motor to turn blender
NEED BLADE FOR BBLFP001 WOLFGANG PUCK BLENDER/PROCESSOR
Go to small appliance repair shop for part. Or they will order for you.
Sep 09, 2015 | Wolfgang Puck Food Processors
Tip
Bringing and blending aplliances
Generally, a blade or grinding or blending/mixing part that is permanently attached to a metal shaft from the appliance motor is held on that shaft by a 'shear pin'. This pin breaks when something is put in the appliance that the grinder, mixer, blender can't gring, mix, or blend. This is to protect the motor from overload. Afterwards, The motor will continue to turn, but the blade or paddle, or whatever will not turn.
The shear pin needs to be replaced.
The shear pin passes through one side of the base of the bade/grinder/paddle assembly, through the motor shaft, and out the other side of the blade/grinder/paddle.
The piece of the pin must be removed from the shaft, and from the two sides of the blending/grinding part. This is generally a press-fit, and some effort may be required to accomplish this.
When the pieces have been removed, a common 'roll pin' of the appropriate diameter should be inserted to hol the turning part on the shaft. It must fit tightly, and some effort should be required to insert the new pin. // '); }// ]]> Back to Edit // '); }// ]]> Publish preview_graphic.jpg
on Feb 07, 2010 | Food Processors
Where to find replacement parts for intertek 3181976
ONLY TO ASK WHERE CAN I FIND PARTS FOR THE juicers BRAND NINJA PRO SERIES 1100 GREETINGS FROM TIJUANA MEXICO.. THANKS
Jun 14, 2013 | Food Processors
I have the Bravetti Platinum Pro food processor. The blender need was not on the processor properly and the little plastic gear was stripped. I need to replace this. Can you advise?
sorry, no.
I went to my parts manuals sites and they did not list this brand.
the internet indicated the problem with this food processor was the inability to obtain parts. I advise keeping an eye on ebay if you need something in particular.
(if this has been helpful, please give me positive feedback)
Aug 16, 2010 | Bravetti Platinum Pro Quad-Blade Food...
The motor runs but the shaft that turns the blade does not turn.
Depending on the processor there are a few things that would cause this. If it isone piece then there may be a little gear box or there can be a direct connect from the motor to a coupler of some sort. On the 'bowl' end where the blades are they will be attached to a shaft. So the gear box could be stripped or worn out, the coupler could be loose on the shaft, or the blades are loose. The last two are the most likely. Usually if it has a gearbox it will juice bricks.
You need to see if you just need a replacement bowl or if it is the drive end. This is a bit tricky but you need to remove the bowl (or blender or?) stop the blades with something other than a finger ie a chopstick or knife. Then try to turn the shaft or coupler. If it turns then something is loose on that end. If it won't that means the coupler and blades are still on. There may be a safety on the power/base that will stop it form working without a container so its a bit harder to check. Usually it is just a rod that is pressed down.
It's worth a try but if you just check the container end carefully it will tell you just as well.
Once you know which end is the problem you can figure out what to do with it. If it is the blade and container end. That can be replaced fairly inexpensively. If it is the power end that can be as much or more than a entire new blender. You can get repair parts from the manufacturers repair depots or a repair parts place. A quick search with the make and model and repairs parts should find you several sources. As well you can go to the company website and look for repair under support.
Jul 07, 2010 | Food Processors
The Blender attachment will not turn, just grinds and smokes.
The motor shaft that spins the teeth that are on the base of the blender may be frozen up for some reason. If you purchased the duet within the last 3 years and have a receipt, call Cuisinart to get it repaired in warranty - even if you don't have a receipt, your serial number may still save you. If you purchased it more than 3 years ago, let me know.
Mar 12, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Plastic gear broke
So, rather than pay for an entire new motor and wait for two weeks forthem to get it to me, I just made a new gear/broken thing. I crazyglued the old piece back together again and used it to make a plastermold...like the way people do with their kid's hands. Then I filledthe mold with JB Weld and let it dry. After that, I drilled a hole inthe new JB weld gear so that it would fit over the metal part in thebullet(that actually spins).
Glued it on (with more jb weld) and the thing has been making my smoothies and grinding my coffee with no more issues.
Sounds complicated, but it wasn't too bad. Funny thing is, the newpiece is probably heaps stronger than the cheap plastic thing thatbroke in the first place.
Do it yourself, or e-mail me: sanfransimo@gmail.com
I'm tired of made-to-break products and could make anyone else one of these things for around 10 bucks!
Feb 14, 2009 | As Seen On TV Magic Bullet Food Processor
Blender Dead as a Doornail
open unit wil find thermal fuse replace.alternative the lid that covers bowl normally turns cliickinto position .this activates aswitch check if properly locked in
Mar 21, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Food Processors Logo
288 people viewed this question
Top Euro-Pro Food Processors Experts
Lawrence Oravetz
ray gallant
Outback Jack
Outback Jack
Are you an Euro-Pro Food Processor Expert? Answer questions, earn points and help others
