Question about Neff Ovens
How to remove neff slide n hide oven door - Neff Ovens
SOURCE: neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Posted on Oct 20, 2008
  • 1462 Answers
SOURCE: Neff Oven Door Removed Incorrectly
you need to lock the hinges to get the door back.
it needs some strength
lay door flat on floor
force hinge against the spring until right back and put the locking arm over. i use my feet for this!
Posted on Nov 29, 2008
mastatech
  • 478 Answers
SOURCE: Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Posted on Mar 12, 2009
jyackle5
  • 8197 Answers
SOURCE: Have removed the oven door
On the link below if you click and open on first manual on page 65 tells you how to remove and reinstall your oven door. All the manuals are the same you just need to click on one and get to the oven do removal.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Posted on Aug 11, 2010
woodchuck789
  • 4059 Answers
SOURCE: HOw do I remove me
Open the door to the first stop(where you put it for broil)and pull the door up off the hinges pulling in the direction the door is slanting up.
Posted on Oct 10, 2010
How to remove door to Neff Combination oven C57M70N3GB
you can remove the door but due to its construction it will need to be checked by technician to make sure it doesnt leak energy after repair.
Oct 12, 2016 | Neff Ovens
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
Neff slide and hide oven door handle has come off
It's a door-off job. Possible (I've just done it) but it's very fiddly. All the runners and sprung mechanisms are a nightmare.
Dec 10, 2012 | Neff Ovens
How do I sepate the inside from the outside of a neff oven Bl641 door
Remove the oven door by flipping the hinge catches into their alternative position and lift the door out of the hinge slots (note it is somewhat heavy). Lie the door, outside face down and press down on the glass with both hands until it slides off the mounting pins at the base of the door body. Replacement is an exact reversal.
Feb 18, 2012 | Neff B1641 Single circotherm super...
How do you remove the oven from the kitchen unit? It looks as if it just slides out but it will not move. Are there any fixing points?
With the doors open, if you look carefully down the left and right hand edges, you will see at least 4 screw heads between the very edge of the unit and the rubber seals for the doors.
Remove these and the whole unit should then to be slide out.
If it still wont budge, you must have missed some of the screws.
Nov 02, 2009 | Neff U1721 Double circotherm Electric Oven
Door does not close tightly ? problem with bottom hinges
Yep, sounds like the hinges/springs have been overloaded.
Dont know if it's a Neff problem in particular, but I had a Neff oven with exactly the same problem - it was already installed when I bought my house.
Spoke to Neff who advised this ocours if heavy things like a roasting tray with a heavy bird / joint in it is rested on the door whilst it's open.
Only cure is new spring/hinge units which are not cheap !
Sep 18, 2009 | Neff B1421 Electric Single Oven
Nov 29, 2008 | Neff B1421 Electric Single Oven
Neff oven u1420
Hinges not fitted properly,or possibly wrong hinges
Nov 03, 2008 | Neff U1661 Double circotherm super...
Change Bulbs in Neff U1661 Oven
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
Apr 27, 2008 | Neff U1661 Double circotherm super...
Ovens Logo
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
