Question about Tunturi R25 Rowing Machine Rower
Tension wheel ot of alignment - Tunturi R25 Rowing Machine Rower
Can you adjust the tension on the wheel?
What sort of tension?
Rim loose on spokes: evenly tighten the spokes to add tension ( very high skill required to keep the rim true. Pro help should be sought)
Too much wheel side play: tighten the wheel to frame axle bolt (unless the bearing is gone, then you'll need new hub bearings).
Chain tension too loose: Move the rear wheel away from the pedals by loosening the axle bolt, pulling back to remove most (but not all) or the slack from the chain. Pay attention to the alignment of the wheel in the frame. Tighten the nuts back down
Feb 17, 2015 | Cycling
Tip
How to change a timing belt on a hyundai Elantra 1.5 , 1.6 and 2.0 engine
1.5L And 1.6L Engines
  1. Remove all necessary components for access to the timing belt cover, then remove the cover.
  2. Rotate the crankshaft clockwise and align the timing marks so No.1 piston will be at Top Dead Center (TDC) of the compression stroke.
  3. Loosen the tensioning bolt and the pivot bolt on the timing belttensioner. Move the tensioner as far as it will go toward the waterpump. Tighten the adjusting bolt.
  4. Mark the timing belt with an arrow showing direction of rotation if belt is to be reused.
  5. Remove the timing belt.
  6. If defective, remove the timing belt tensioner.
To install:
0900c1528019701f.jpgenlarge_icon.gifenlarge_tooltip.gifFig. Proper pulley alignment for timing belt installation at TDC-Hyundai 1.5L DOHC engines
0900c15280197020.jpgenlarge_icon.gifenlarge_tooltip.gifFig. Proper pulley alignment for timing belt installation at TDC-Hyundai 1.5L SOHC engines
  1. Align the timing marks of the camshaft sprocket and check that the crankshaft timing marks are still in alignment.
  2. If removed, install the timing belt tensioner, spring and spacer with the bottom end of the spring free. Tighten the adjusting bolts lightly with the tensioner moved as far as possible away from the water pump.
  3. Install the free end of the spring into the locating tang on the front case.
  4. Position the timing belt over the crankshaft sprocket, then over the camshaft sprocket. Slip the back of the belt over the tensioner wheel.
  5. Turn the camshaft sprocket in the opposite of its normal direction of rotation until the straight side of the belt is tight and be sure the timing marks align.
    NOTE If the timing marks are not properly aligned, shift the belt 1tooth at a time in the appropriate direction until they are aligned.
  6. Loosen the tensioner mounting bolts so the tensioner works,without the interference of any friction, under spring pressure. Be sure the belt follows the curve of the camshaft pulley so the teeth are engaged all the way around. Correct the path of the belt, if necessary.
  7. Tighten the tensioner adjusting bolt, then the tensioner pivot bolt to 15-18 ft. lbs. (20-26 Nm).
    NOTE Bolts must be tightened in the stated order or tension won't be correct.
  8. Turn the crankshaft 1 turn clockwise until timing marks again align to seat the belt.
  9. Loosen both tensioner attaching bolts and let the tensioner position itself under spring tension. Retighten the bolts.
  10. Check belt tension by putting a finger on the water pump side ofthe tensioner wheel and pull the belt toward the water pump. The belt should move toward the pump until the teeth are approximately 1 / 2 of the way across the head of the tensioner adjusting bolt. Re-tension the belt, if necessary.
  11. Install the timing belt covers and all other related components.
on Dec 01, 2009 | Hyundai Elantra Cars & Trucks
DEWALT DW100 the blade slips off the driving wheel
There are some possible reasons why the blade slips off. Check the wheel alignment of the saw. If the wheels are not aligned, you have to loosen the shafts to align the wheels and re-secure the wheels to the shafts. Once the wheels are aligned, make sure that the deepest gullet of the blade is on the center on the tire. Then tyr turning the wheels by hand. Check your tires for wear and the tension as well. For more info about band saw , visit bandsawblog.com .
Jun 12, 2013 | Saws
Replaced sway bar, backend is still swaying,when I hit a bump the backend moves like ots fish tailing
Could deff. be the rear struts on this car but could also be that the alignment in the rear is way off causing the wheel that is supporting the most load when hitting a bump or pot hole to pull the car in the desired direction that that whell is angled toward. But if you are leaning towards replacing the rear struts do that first since it also requires a 4 wheel alignment then all the bases are covered. Otherwise if you try the alignment and that isn't it you will have to pay for a second alignment after the struts are replaced.
Dec 30, 2011 | 2004 Pontiac Grand Prix
What is the wheel alignment on the flsts?
The wheel alignment is fixed and cannot be changed between the front wheel and the rear wheel. Also, different models of bikes may or may not have an offset between the front and rear wheels.
The only alignment that you have any control over is the alignment of the rear wheel inside the swingarm. It must run parallel to the swingarm. The way you get this is by adjusting the rear wheel to where the length of the adjuster bolts are the same on both sides of the swingarm when the belt is at the proper tension.
Good Luck
steve
Sep 15, 2010 | 2000 Harley Davidson FLSTS Heritage...
2002 Dodge Caravan. Front tires worn to the belts only only the very inside. What pieces are worn out. Thanks
may not be worn out suggest alignment most alignments are around 40.00 hope i helped!!
Aug 16, 2010 | 2002 Dodge Caravan
Changing the timing belt on a Hundai
  2. Rotate the crankshaft clockwise and align the timing marks so No. 1 piston will be at Top Dead Center (TDC) of the compression stroke.
  3. Loosen the tensioning bolt and the pivot bolt on the timing belt tensioner. Move the tensioner as far as it will go toward the water pump. Tighten the adjusting bolt.
  4. Mark the timing belt with an arrow showing direction of rotation.
  7. Align the timing marks of the camshaft sprocket and check that the crankshaft timing marks are still in alignment.
  8. If removed, install the timing belt tensioner, spring and spacer with the bottom end of the spring free. Tighten the adjusting bolt slightly with the tensioner moved as far as possible away from the water pump.
  9. Install the free end of the spring into the locating tang on the front case.
  10. Position the timing belt over the crankshaft sprocket, then over the camshaft sprocket. Slip the back of the belt over the tensioner wheel.
  11. Turn the camshaft sprocket in the opposite of its normal direction of rotation until the straight side of the belt is tight and be sure the timing marks align.
    NOTE If the timing marks are not properly aligned, shift the belt 1 tooth at a time in the appropriate direction until they are aligned.
  12. Loosen the tensioner mounting bolts so the tensioner works, without the interference of any friction, under spring pressure. Be sure the belt follows the curve of the camshaft pulley so the teeth are engaged all the way around. Correct the path of the belt, if necessary.
  13. Tighten the tensioner adjusting bolt, then the tensioner pivot bolt to 15-18 ft. lbs. (20-26 Nm).
  14. Turn the crankshaft 1 turn clockwise until timing marks again align to seat the belt.
  15. Loosen both tensioner attaching bolts and let the tensioner position itself under spring tension. Retighten the bolts.
  16. Check belt tension by putting a finger on the water pump side of the tensioner wheel and pull the belt toward the water pump. The belt should move toward the pump until the teeth are approximately 1 / 2 of the way across the head of the tensioner adjusting bolt. Re-tension the belt, if necessary.
  17. Install the timing belt covers and all other related components.
Feb 09, 2010 | Hyundai Motor 2004 Sonata
Needing schematics for timing belt on a 2000 se
Removal & Installation
2.0L Engine
  1. Remove or disconnect the following:
    Negative battery cable Spark plugs Catalytic converter Right front wheel Right inner splash shield Accessory drive belt and idler pulley
  2. Rotate the crankshaft to Top Dead Center (TDC) and install Crankshaft TDC Timing Peg T97P-6000-A.
  3. Rotate the crankshaft clockwise against the peg.
  4. Remove or disconnect the following:
    Water pump pulley Valve cover Crankshaft pulley Timing belt covers
  5. Install Camshaft Alignment Timing Tool T94P-6256-CH into theslots of both camshafts at the rear of the cylinder head to lock thecamshafts into position.
  6. Loosen the timing belt tensioner bolt and relieve the tension onthe timing belt by disconnecting the tensioner tab from the timingcover back plate.
  7. Remove the timing belt.
    0900c152801e2a75.jpg enlarge_icon.gifenlarge_tooltip.gifFig. Crankshaft alignment position-Ford 2.0L (VIN 3) engines
    0900c152801e2a76.jpg enlarge_icon.gifenlarge_tooltip.gifFig. Placement of Camshaft Alignment Timing Tool T94P-6256-CH-Ford 2.0L (VIN 3) engines
    0900c152801e2a77.jpg enlarge_icon.gifenlarge_tooltip.gifFig. Timing belt tensioner index marks-Ford 2.0L (VIN 3) engines
To install:
NOTE Always replace the timing belt after loosening or removing it.
  1. Install the timing belt.
  2. Engage the timing belt tensioner tab into the timing cover back plate.
  3. Adjust the timing belt tensioner until the index marks are aligned. Tighten the tensioner bolt to 17-20 ft. lbs. (22-28 Nm).
  4. Remove the camshaft alignment tool and the crankshaft TDC peg.
  5. Install or connect the following:
    Timing belt covers Crankshaft pulley. Tighten the bolt to 81-89 ft. lbs. (110-120 Nm). Valve cover Water pump pulley Accessory drive belt and idler pulley Right inner splash shield Right front wheel Catalytic converter Spark plugs Negative battery cable
  6. Start the engine and check for proper operation.
Apr 08, 2009 | 2000 Ford Contour
Rubber bands pop off of wheels
My Delta 14" had the same problem. My fix was to get new rubbers, took care of my issue. They do stretch, but the newer the rubbers are the more the will retain there form, the older they are, not so much.
anaanymous
Oct 10, 2008 | Ridgid 14" Band Saw with Stand
Different letter appears from the one i've typed
Sounds like the wheel is out of alignment. I had this problem with the one I recently purchased for my daughter. Release the tension on the ribbon and head. Pull the wheel cartridge out and line up the letters. Put the wheel back and reapply tension. Repeat until it is aligned. Took me a couple tries to get it working, but its working and seems to be stable.
Nov 07, 2007 | Brother GX-6750 Typewriter
Tunturi R25 Rowing Machine  Rower Logo
29 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
