Question about Proform 680 LT Treadmill
PROFORM ERROR CODE - Proform 680 LT Treadmill
Error code on a pro form 995 treadmill. 4 blinks
Hi Dan ,
You may need to ring Icon Fitness for further help .
Sep 13, 2014 | Proform Power 995 Treadmill
I have a Proform 415 CT. When I put the key in place i get a FF code. I've tried unplugging overnight but still doesnt work. How do I fix this problem?
iFit card had scrambled the computer memory. Their solution to replace in the iFit card slot and it would reset the computer memory on the machine.God bless you
Mar 23, 2013 | Proform Exercise & Fitness
Proform performance 400 rattling
what problem do you have error codes, lack LUBE, Elevation motor?
waiting from your comments, i remain sincerely.
However you can RUN the software calibration for diagnostic, troubleshooting and fix it.
God bless you
Oct 07, 2012 | Proform Performance 400 Treadmill Exercise...
I have pro-form esp 10 w/ the console does not function/an error code(EEEE)
see the diagram attached, and adjust the REED switch, clean, and tight the connector very well.
tight the ribbon cable from keypad + tigh the connector from display board vs lower board.
after your fix it RUN the software calibration for diagnose and troubleshooting.
See my perssonal tips for Help.
sincerely. God bless you
May 01, 2012 | Proform Exercise & Fitness
Proform 725 error code E22
Dear Sir:
The walking deck belt, had different speed that displayed in you display window.
Indicate stress in the motor by locked rotor.
Go to RUN the software calibration, for easy diagnose and troubleshooting.
Follow your steps in your user manual.If you do not have download for www. proform. com .
atached is diagrama for adjust the speed sensor. after RUn THE S. CALIBRATION.
ernesto cuadra
managua, nicaragua. c.a
Apr 04, 2012 | Exercise & Fitness
Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jul 15, 2010 | Proform Exercise & Fitness
Proform 490C showing error code ssytem cehck
The checksum failure is an indication of a bad console on this model. If the machine is brand new then it still has a warranty. Contact the number on the front of your manual they will replace it for free. Good luck, Tim
Nov 09, 2009 | Polar Exercise & Fitness
Proform 725 treadmill - error code"PO" and "E21"
Check there is controller inside on which there is DZ1 and DZ4 diodes which usually get damaged/burned out. I dont know values of the diodes but replacing them would solve the purpose.
Dec 24, 2008 | Cycling
Proform 680 LT Treadmill Logo
20 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
