Question about Nokia N70 Cellular Phone
3650 problems hi does anybody knows how to format phone 3650???in 6600 same process *+#+call.???? any body could help???? how to run as safe mode in 3650???? any advised will highly appreciated thankssss!!!!!!
  • santini_marf Jan 26, 2009
    navas1405 thanks!!!!i appreciated it but i knew it already, all i want to know is how to run as save mode with my 3650 so that i can format it using that codes??? when i always turn it on it stops start up... start up failed contact phone retailer.... is there any advise???to run as safe mode????so that i can use *#73703???? thanks!!!!
  • 73 Answers
To format your cell phone, you need to dial *#7370#.
Posted on Jan 28, 2009
    Problem Solver:
  • 8 Answers
AT SAME TIME U CAN NEED TO PRESS *+3+CALL HOLD THIS BUTTON AND SWICTHOFF AND ON WITHOUT RELEASE OR TRY THIS ALSO *#7370#
Posted on Jan 26, 2009
Tip
How to Format ur s60 nokia phone
Its important to read through this topic before you proceed with formatting, you will need to charge your phone at least half full to enable a successful format.
Soft Reset *#7780# : Restores ini files from rom but preserves user data (photos, 3rd party apps etc) - Hard Reset *#7370# : This reformats the C: drive completely and all applications and files stored on this drive will be lost. *
With *#7370# and *#7780# the lock code will be asked before formatting the phone so be sure to remember your code, the DEFAULT CODE by nokia is 12345. *
Firstly you might want to make a back up of all your important bookmarks, calender, notes and contacts, Using file manager go to c:/system/data find bookmarks.db for bookmarks, calendar for calendar, notepad.dat for notes, and Contacts.cdb for contacts. *
Contacts can only be copied when phone is in offline mode/flight mode, use Psiloc System Tools for flight mode, not needed on 6630 or later. Or you can use Contact Manager app *
Ok so 7650, 3650, 3660, ngage and ngage qd can only be formatted using *#7370# Before your format, be sure that the problem is on phone, remove mmc and see if problem still exists. *
Also try starting in safe mode (press and hold pencil/abc key while turning on till op logo comes up). You can solve an apparent problem with simple solution
6260, 6600, 6620, 6670, 7610, 6630, 6680, n70 etc: Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. Keep pressed until phone boots up. *
Fonts and Formatting. If you have any fonts installed be sure to remove them using Font Remover app or go to c/ or e/ system/ fonts/ and rename it to whatever and delete it now reboot phone before you attempt format. *
and above all,this is very important,don't mess with file explorers (delete,rename,alter files) if you don't know what your doing. *
and yes,formating phone (soft/hard) can screw some app's on mmc. Some will work fine,others don't coz they share files on both drives (c:/e: ) *
OPERA - to copy opera bookmarks before formatting mmc, assuming opera is installed on e-drive. e/system/data/opera/bookmarks
don't forget to click the THANKS button.
Closed Thread
on May 12, 2010 | Cell Phones
Forget security code
Problem with Nokia 1100 1101 1108 1110 1112 1200 1208 1255 1315 1600 1650 2112 2118 2255 2270 2272 2275 2280 2285 2300 2310 2355 2600 2610 2626 3100 3105 3110 3120 3125 3600 3620 3650 3660 6030 6085 6086 6108 6230 6268 6270 6282 6600 6620 try theese .
Dec 27, 2013 | Nokia 1100 1101 1108 1110 1112 1200 1208...
Hi guys, I have some problem with my Nokia Phone 6600, Since few days i have some problem in SMS, the problem is if anybody sends the sms, it remains in Inbox as well as it goes directly to Outbox and...
Try to format your phone manually by typing this code *#7370# if security code prompted just type the default securitycode or your personalized security code and wait until the phone completely rebooted.Also try to scan your mmc if it has a virus.
Jan 20, 2010 | Nokia 6600
Want to delete Outbox permanatly
What you need to do is to format your phone,cause normally at first 6600 does not do that except it has contacted a virus.you need to format it.
Follow this proceess.....
First switch off your phone,
Power on from the power pointing,
Ones it powers on immediately it displays nokia on your screen.press down your * bottom,number 3, and your send bottom.
Hold down those bottom down until it shows a black screen moving from the left.
.NB.Don't remove your hands until the black screen finishes.after then you phone will work better. try it its fun.
Gallery is showing busy.
I think the memory is overloaded. A phone usually recognizes when the memory is less but in your case the phone failed to recognize the increasing load and got overloaded. Thus to get it out of load, reformat the phone memory. For this you need to Turn off your phone. Then press and hold the green call button ( the button you press when you receive call or take call ) and while doing it press the " 3 " No. on the keypad and also the " * " key while pressing both Green and 3 Key. Be sure you don't disengage any of the buttons. And in that state of 3 keys ( Call, 3 , * ) pressed, Turn on the phone. This can be difficult, for it you can take help from any other person to press the keys. As soon as the phone is switched on, the memory format process will start and the original data and features will be restored to the phone. The 1st formatting process may be difficult so I will give you an easy way. Only enter and dial *#7370# code and the formatting process will start.
WARNING :---- The first process formats the memory card to factory settings with all your data safe, but the second process involving the code will cause loss of program files on your phone. It will not harm but you will lose your personal, official, etc all types of files which you installed.
Thank you Sir, Have a nice day.
Sep 23, 2009 | Nokia 6600
Nokia 6600 keypad malfunction
TRY THE MANUAL FOUR BUTTON PRESS FORMAT THAT IS SWITCH OFF YOUR FONE, THEN PRESS DOWN *3 THE GREEN BUTTON AND SWITCH ALTOGETHER AT ONCE AND HOLD DOWN TILL SCREEN DISPLAY FORMATTING
Aug 24, 2009 | Nokia 6600
HOW TO FORMAT HANDPHONE SONY ERICSSON
how to format handphone sony ericsson g900....could anybody help me...
Feb 17, 2009 | Nokia N70 Cellular Phone
3650 phone start up failed pls help me
u have to reset or mobile ..to do that follow this
1. Removed your MMC card first.
2. Make sure you have at least 3/4 charge of battery before performing the
" Safe Mode, and follow-by phone reset *#7370# ". Or maybe you can have the
charger on and plugged into the phone to act as a full power source.
3. Press and hold the ABC key and then press the power button.
Remember not to release the ABC key till you seen the
"Safe Mode" standby screen.
(Fyi, there's no special indicator that telling yo're on a "Safe Mode"
standby screen.)
4. Once in the "Safe Mode" stanby screen press *#7370# to carry-out "Phone Reset"
task.
5. Once "Phone Reset" task completed and back to normal standby screen again,
switch off your phone and re-insert your MMCmag-glass_10x10.gif card.
If any error showing on the phone boot-up, please have the memory card formatted and by next phone
start-up you will not have the error msg again.
If you some important data or programs files on your MMC card, please use
a card reader to have them copied onto a pc before performing memory card
formatting
Dec 04, 2008 | Nokia 3650
Bettery Problem or other
11927ac.jpge77ddac.jpgImran, As you know 3650 & 6600 both are WD2 platform of Nokia. There are very much similarity in this models, I don't have images of 3650 so i m sending same problem solution images of 6600, this is similar applicable in 3650. Your problem will be solved. But don't try to do anything with phone circuit if you are not enough skilled and trained. This is hardware problem of above depicted area.
Jan 16, 2008 | Nokia 3650
Nokia N70 Cellular Phone Logo
76 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
