Question about Philips DVP642 DVD Player
No Power Was watching a DVD when it finished and i went to press the stop & eject button.. Upon doing this the screen went blank flickered and the DVD player lost power... I turned it off at the machine & back on again. Nil power again. Unplugged the machine, tried it in another power point and still no power. I am no unable to get the disc out of the tray (since i cant get any power to the machine) Can u pls adivse what problem the no power could be, and how i can get the disc out of the mahcine. I tired to open the DVD player with a screw driver but unfortunately, it has screw-like things that require a special tool to open them.. .Its a Philips DVD player # 736k model.. (which isnt on the below list) Thanks very much
  • Anonymous Feb 03, 2009
    DEAD
I came up with this problem as well. I think the issue comes up when the unit over heats. I opened up looking for a power supply issue, and have not been able to find any capacitors that might have blown. First time this happened, I waited a few hours, and the unit slowly started to come back to life, and I was able to eject the disc. You can hear the player attempting to spin the disc, but failing to, then going back to off mode. Pressing the play or power button attempt to start the disc again.
This is only a temporary solution for this problem. I am working on finding the direct cause of this issue.
Posted on Jun 19, 2009
  • 25 Answers
IF YOU ARE FAMILIAR WITH A SOLDERING IRON THIS IS A VERY SIMPLE FIX, IT IS SIMPLY A MATTER OF FAILED CAPACITORS ON THE POWER SUPPLY COMPONENT BOARD.
USUALLY A PAIR OF THEM OR MAYBE 3, VERY SIMILAR TO THE SAME ISSUE WITH PHILIPS DVP-642 MODEL.
REMOVE THE TOP <WHICH YOU HAVE TO DO TO REMOVE THE DVD> AND YOU WILL SEE THE BULGED OUT CAPACITORS, THEY WILL PROBABLY HAVE GUNK ON TOP OF THEM.
Posted on Feb 14, 2009
My player would not eject the disc and when you tried to turn the unit on the standby light would just blink. Following the advice above...sure enough I opened it up and started looking at the capacitors on the power supply board. There's only two boards in the DVP642 plus the disc reader. One of the capacitors had a slight bulge at the top and the bottom. I used the same size (1000uf) but a larger voltage. The voltage didn't really make a difference. Soldered in a new one and it was good to go. I'm surprised that was all that was wrong with it. Thanks.
Posted on Jul 06, 2009
My MusicPad Pro Plus will not power up.
Probably your battery packs won't hold a charge any more. See my post here
Jan 03, 2014 | FreeHand Systems Freehand MusicPad Pro...
Why I can't open or close the dvd tray?
You need to unlock the tray. The instructions are in your owner's manual.
Common unlock codes are:
Power off the DVD and hold the stop button for 5 seconds, then press eject.
or
Power off the DVD and hold the eject button for 5 seconds
Some models need the power on when you do this. I could not find an online manual for details.
Feb 21, 2012 | Sanyo DVD-SL20 DVD Player
I put in a dvd into the dvd player, and went to eject it. I pressed the eject button and a "locked" caption came up on the screen. I dont have the owners manual and I cant figure out how to...
You may have enabled the child lock feature, try pressing the Return, Enter and Power buttons together to toggle the lock off. If this is disabled and you still can't open the tray, turn off the unit and unplug it. After 30 seconds or so, plug the unit back into the electrical outlet. Attempt to open the tray. If this does not solve the problem, try pressing Power + Stop + Eject buttons together. Also try pressing Disc1 + Stop + Eject simultaneously (if a disc1 button is on the remote or player).
If the error message is t - L C K or persists after trying all of the above steps, then you need the unit serviced.
The manual is available at the Sony support site: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPSR200PB .
I hope this helps.
Apr 16, 2011 | Sony DVP-SR200P DVD Player
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
2003 Honda Accord Ex - navigation stopped functioning
Hi, it could be that the screen is in the off position, press daylight/night button twice. From what I've read in other forums pressing that button twice turns the sat nav screen off. Buying an updated DVD will not solve the problem. you can also try a dvd cleaner.
Your lucky if your progress bar has fully loaded up. Mine hung up with about 2% and will not respond in any way now, I have to send it away to Alpine for fixing. Hope this helps
Jul 09, 2009 | 2003 Honda Accord
Disc Finalize stuck at 99%
press OK button on the remote of the DVD to take finalize 99% off the screen , then EXIT button
Mar 01, 2008 | RCA DRC8335
Will not turn on or reset
First try pressing and holding the stop and channel up buttons (at the same time) on the unit (not the remote) for about five seconds.
If that doesn't work, try pressing and holding the stop and power buttons at the same time.
Jan 02, 2008 | Panasonic DMR-ES20EG DVD Recorder
Cannot remove progressive scan mode
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
DVD went in...and won't come out
Whatever you do, DON'T try ejecting it manually. it can ruin the dvd mechanism. The problem is in the dvd power supply. If you have some soldering skills and are good with a soldering iron(temperature controlled is best) you can resolder all the three-legged regulators on the dvd power supply board(small board to the right front of chassis). Good success, Meder's Tv
Feb 20, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Philips DVP642 DVD Player Logo
292 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
