Question about LG LS-L1210CL Mini Split Air Conditioner
Lg split system ch 05 error outside fan not working
  • 30 Answers
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Posted on Feb 16, 2009
LG split system CH24
Posted on Dec 07, 2010
Remote will not bring unit on . have changed battery
Posted on Dec 17, 2009
What does the code on the screen mean flashes between ch and 05 ?
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
Oct 15, 2016 | LG Art Cool LA181CNW Split System Air...
How to fix LG error code ch 23
there is a problem with a sensor ,but it must to change both(because are 2 senzor )even is broken just one.this senzors are locate in outside unit.
Nov 21, 2013 | LG LSC091PMA Split System Air Conditioner
Error code ch 05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Feb 03, 2011 | LG Art Cool LA181CNW Split System Air...
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
What is error code ch o5
CH-05 Communications Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Oct 06, 2010 | LG LSC183VMA Split System Air Conditioner
LG air condotioner with a CH5 error code
CH-05-Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jul 27, 2010 | LG L1004R Air Conditioner
Error Ch 26
1.check indoor unit wiring.
2 check cirkit board
3 check selector switch
Mar 25, 2008 | LG LSC183VMA Split System Air Conditioner
Error ch 5
check all wiring and connections - ch 5 is a communication error between the indoor unit and the outdoor unit......
Dec 09, 2007 | LG LSC183VMA Split System Air Conditioner
LG LS-L1210CL Mini Split Air Conditioner Logo
2,461 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
