Hp model c-uq hp1 - Office Equipment & Supplies
Download driver c-uq-hp1
old post
why not ask hp.
https://h30434.www3.hp.com/
Dec 25, 2013 | HEWLETT-PACKARD HP DeskJet 1600C/CM/CN...
How to stop motor make noice
replace the bearing...they are the noise makers
Apr 25, 2013 | Hayward Pool & Spa
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
Jul 28, 2009 | Magic Chef Microwave Ovens
Hi, when I want to open scaner in hp office jet6213 I recieve this message "selektskin-error" (the file c:program fileshpdigital imageskinsoov1skin.xmldose not exist) What should I do?
The 'missing' file exists, but is in the wrong folder. This problem is known to HP. Here is the solution:
# Open Windows Explorer.
# Click the + sign next to Local Disk (C:).
# Click the + sign next to Program Files .
# Click the + sign next to HP or Hewlett Packard .
# Click the + sign next to Digital Imaging .
# Click the + sign next to Skins .
# Make sure there are only two folders; one named hp1 and one named 00v1 . If there are any variations to the folder name, or extra folders, delete them.
# If there are not any extra folders, check the contents of the folder and make sure they are correct.
1. Look inside the hp1 folder; it should contain sixteen icons (including folders).
2. Look inside the 00v1 folder it should also contain sixteen icons (including folders).
What you will probably discover is that the skin files in the 00v1 folder are all or partially missing. Copy all the files in the hp1 folder to the 00v1 folder, and be sure skin.xml is one of these files. And if there are any other folders in that subdirectory delete them, and if the 00v1 folder is missing, create it.
You can go to the following site for a deeper discussion of this error message: http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00215691&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Apr 28, 2009 | HP PSC 1315 All-in-One Printer
File xmlparse.dll is missing for H P Director
Try this temporary cure given by HP, until they release a patch. It will give you access to the Hp director. It worked for some people, just pay attention to the instructions it gives you>> http://www.geocities.com/contacthptech/hp1.js It will probably ask for your HP instalation CD.
*Drop me a comment if you still have problems. I will assist you.
Dec 29, 2008 | HP Compaq dc5700 Microtower - Free Flat...
EVERY TIME I use my scanner ie scrips errors involving - file:///C:/Program%20Files/HP/Digital%20Imaging/Skins/hp1/sc/scan.htm comes up
Hi I encountered a similiar problem with my HP PSC 2310 printer recently. "file:///C:/Program%20Files/HP/Digital%20Imaging/Skins/hp1/sc/scan.htm". Following are the soultions provided by HP team. Solved mine using solution #1. Hope this is of help :)
Solution 1:
1. Double-click on 'My Computer' icon on the desktop.
2. Double-click on C:
3. Double-click on 'Program Files'.
4. Double-click on 'HP' folder.
5. Double-click on 'Digital Imaging' folder.
6. Double-click on 'Skins' folder.
7. Locate and double-click on 'hp1' folder.
8. Locate, right-click on 'skins.xml' file and select 'Copy'.
9. Click on the 'Back' arrow to go to the 'Skins' folder.
10. Double-click on 'hp2' or 'oov1' folder.
11. In the folder, right-click on any blank space and select 'Paste'.
12. Now restart your computer and check the functionality.
If the issue still persists, please follow solution 2.
Solution 2:
1. Insert the All-in-one software CD in your computer and cancel any installation screen that may appear.
2. Double-click on 'My Computer' icon.
3. Right-click on the CD-ROM drive that contains the software CD and select 'Open'.
4. Double-click on the 'Setup' folder.
5. Double-click on the 'SkinsHP' folder.
6. Right-click on the file 'SkinsHP1.MSI' file and select 'Install'.
7. Again right-click on the file 'SkinsHP1.MSI' file and select 'Repair'.
8. Restart the computer and check the functionality.
Solution 3: Uninstall and reinstall of the software.
1. Insert the CD that came along with the printer.
2. In the CD contents, you will be able to view a folder named "UTIL".
3. Inside the UTIL folder there will be a folder named "CCC".
4. In the CCC folder, among the various files, you will be able to view four files named, Uninstall_L1.bat, Uninstall_L2.bat, Uninstall_L3.bat and Uninstall_L4.bat.
5. First double click on Uninstall_L1.bat file. A black DOS window will open up. This will uninstall the software by Level 1 method. It will take a while until Level 1 uninstallation is complete.
6. Similarly complete level 4 uninstallation by clicking on Uninstall_L2.bat, Uninstall_L3.bat and then in Uninstall_L4.bat.
7. This completes level 4 uninstallation of the software.
8. Now install the software from the CD and check if the issue is resolved.
Cheers,
kypsyche
Jul 10, 2008 | Office Equipment & Supplies
May Tag Dishwasher
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07094.html
I think you should review this webpageThere have been over 2 million maytag dishwasher recalls due to them being a fire hazard. The chart below came from the site and Im not sure what your serial number is but your model number is on there.
Brand Model numbers MUST
begin with… AND serial numbers MUST end
with… Maytag® MDB3, MDB4, MDB5,
MDB6, MDB7, MDB8,
MDB9, MDBD, MDC3,
MDC4, MDC5, DWU9 SM, SQ, SS, SU, SW, SY, SZ, UB,
UD, UF, UH, UK, UM, UQ, US, UU,
UW, UY, UZ, WB, WD, WF, WH, WK,
WM, WQ, WS, WU, WW, WY, WZ,
YB, YD, YF, YH, YK, YM, YQ, YS, YU,
YW, YY, YZ Jenn-Air® JDB3, JDB4, JDB5,
JDB6, JDB7 UB, UD, UF, UH, UK, UM, UQ, US,
UU, UW, UY, UZ, WB, WD, WF, WH,
WK, WM, WQ, WS, WU, WW, WY,
WZ, YB, YD, YF, YH, YK, YM, YQ,
YS, YU, YW, YY, YZ
Mar 30, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
78 people viewed this question
jasbo
jasbo
