Question about Car Audio & Video
Alpine XQE 100240 6CD Changer - magazine and CD stuck
6CD stacker/changer from a Range Rover has a CD stuck in machine. Tray that carries CD wil not retract back into the carrier. HAve remove unit from vehicle and have taken cover off but cannot seem to un-jam unit. Need help finding a repair manual and or suggestions on how to repair unit.
  • Anonymous Apr 18, 2009
    My 6 cd changer stuck inside the player with a disk extended into the "play" side of the unit...I took the unit out of the car, took the cover off, manually manipulated the extended tray and found a switch that would "spring" it the whole cassette out of the player so I could rtrieve my prescious disks....reconnected unit, and it would not play...not sure if there are internal fuses that may be burnt? Impossible to see if the cd changer unit is getting power....
4 Suggested Answers
SOURCE: Alpine CHM-S620 CD Changer Magazine
if you open the cage on the unit, you can pop the tray back out of the mechanism by VERY GENTLY turning the load gear on the carriage, be sure to not slip any gears on the drive or the changer will be out of sync and will be garbage unless you have it serviced by an Alpine service center. you are best to turn the 1st. gear beyond the carriage motor, or you can apply power to the motor (which I don't advise) to let the motor eject the tray. if you do choose the power method, be 100% sure of the polarity first otherwise you will damage the carriage and drive gears. the motor has a brass gear and the rest are nylon gears, the brass gear will very easily shred a nylon gear. want to be extra careful? manually turn the load motor gear itself, it will take alot longer to do, but will be the safest. I've been inside these machines quite a bit, hope I was able to help.
Posted on Sep 18, 2008
landsend
  • 1066 Answers
SOURCE: which radio for land rover
Usually an Alpine unit.  Try ebay.
Posted on Apr 03, 2009
dj_relly999
  • 4070 Answers
SOURCE: cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
Posted on Feb 10, 2010
partyd
  • 141 Answers
SOURCE: Need to eject Alpine Renault 6CD changer cartidge- no power?
lok at the 8 pin plug the first pin from the left is the power wire and the round metal part of the plug is the ground
good luck
the last pin on the right is the ignition
Posted on Apr 01, 2010
My cd stacker comes up wit erorr 2 on the screen the car battery was replaced dose it need a code
in many of these changers error 2 means there is a cd stuck in the player, inserting an empty magazine for it to slid into often helps
Jan 12, 2015 | Clarion UC 6 CD Changer
My alpine CD player is showing a cd 3 error jam
Are all CDs in the magazine? If not, there may be one stuck in the changer
Sep 23, 2012 | Alpine Car Audio & Video
Error 01 the magazine does not eject
A lot of times there is a gear inside of the changer that gets jammed. If you can, remove the top cover of the changer. On the changer mechanism (it will be on the right side of the changer) there will be a large gear (probably black) with an arm attached to it. Use a flat blade screw driver or something like that and turn the gear counterclockwise until the tray is back in magazine. You should then be able to put the changer back together and it will probably work fine.
Nov 02, 2011 | Alpine CHM-S620 6-Disc CD Changer
Can not get the magazine to eject have a fuse but everytime i reset the fuse i get a little juice but then nothing, What fuse should be used on this unit and where is the manual eject/
you have to open the cd changer and you will notice that 2 or 3 disc move to the right side under the tray or on top
pusch them back into the cd magazine but don't force the unit and don't move the disc on the tray
now power it again and press eject
good luck
Nov 18, 2010 | Alpine CHM-S630 6-Disc CD Changer
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
Cd changer magazine does not eject
Feb 09, 2010 | Alpine CHM-S630 6-Disc CD Changer
Which radio for land rover
Mar 24, 2009 | Alpine CHM-S620 6-Disc CD Changer
''CDDJ ERROR'' WHEN ATTEMPTING TO PLAY VIA ALPINE CHANGER
My local Lincoln Dealership wanted to dismount the actual Clarion CD changer (I thought, and unfortunately reported to you, that the CD changer manufacturer was the same as the radio/cassettee unit that is installed in my dash, Alpine) from my 99 Town Car and ship the unit out for repair for a minimum of $130.00. Instead, I went to a local Radio Shack franchise who installs/repairs car electronic audio/video systems and they: dismounted the unit from the trunk; took the dismounted unit to their workbench; removed all the housing, etc. and finally were able to manually extract the fully populated 6 CD magazine stuck within the CD changer. Additional efforts (including inserting my spare magazine into the CD changer while it was on the tech's work bench) to determine exactly why the magazine would not eject while the unit was connected via the cabling to the car's power, etc. were not productive. So I now have a totally unassembled non-functioning CD changer on my hands. The "CDEJ Error" on the LED area in the dash when the eject buttoon on the CD changer is pushed.still persists. The technician said that it would be a waste of his time and my money to re-assemble the parts of the CD changer. He believes that the motor on the unit has been burned up.
So I am now checking with all the local auto parts salvage yards (we used to call them junk yards) to see if anyone has a usable Clarion CD changer for a 1999 Lincoln Town Car available that would be plug compatible with my existing Alpine factory installed Premium CD/Cassette audio system and the former factory installed trunk mounted Clarion CD changer. The Radio Shack franchise technician has already checked with the Clarion factory people and they iindicated that they no longer have my Town Car installed CD changer model available, new, used, refurbished or otherwise.
For what it's worth, here are the part numbers and other potentially important data that appear on the "cage"/sheet metal/housing that surrounds the working parts of the CD changer itself:
Assembly Part Number: F8VF-18C849-AE
Part Number (presumably the "cage"?): F8VF-18C830-AE
Date Code: 0998
Serial Number: 0201832
Mounting Orientation: Vertical
System Revision Level: 9.2
So it looks like I may have a potentially very expensive replacement of my whole audio system on my hands. I have been quite happy with my somewhat "obsolete" audio system and I have a very large collection of CDs which I migrate between my Sony 300 CD CDP-CX350 Mega Changer installed in my entertainment center, my car Cd changer and my Sony CD/Cassette player boom box in my master bedroom.
It was suggested to me that if I have to replace the radio/cd/cassette unit installed in the dash of my Town Car that I should consider a replacement model that offers a port to receive Ipod programming as a source of music.
So things have gotten somewhat complicated since the first instance of the Cd magazine not ejecting from the Clarion CD change mounted in the trunk of my car.
Maybe someone out there on your knowledge base knows where I can acquire a used Clarion model CD changer compatible with my car's setup at a reasonable price.
Thanks,
Tom
Nov 24, 2008 | Alpine CHM-S620 6-Disc CD Changer
May 14, 2008 | Alpine CHM-S620 6-Disc CD Changer
Car Audio & Video Logo
1,827 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
