Question about Panasonic TH-37PX60U 37 in. Plasma HDTV
Why is a large green square on my plasma tv screen
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
Problem with the LG 42PC3D 42 in. Plasma Television Horizontal half black screen, sound is still there
Sorry this tv it is not repairable because the tv Plasma screen panel itself it is the tv problems and the causes,this tv only can be repair by replace the whole new tv Plasma screen panel itself only not practical.Because the tv Plasma screen panel are 90% inportant to the tv functions and the cost of the tv.By replacing the tv Plasma screen panel will cost the same as a new tv.
Sep 22, 2011 | LG 42PC3D 42 in. Plasma Television
Today 12/16/2010 my HDTV 42 in plasma model 42px12x.41. made a "popping" sound in the back of the screen and the screen went black,( yet there is still sound and a couple of green and red light...
PLASMA TVS DONT HAVE INVERTER CIRCUITS. YOU MOST LIKELY HAVE A Y-SUSTAIN BOARD FAILURE. IT IS THE BOARD TO THE LEFT LOOKING FROM THE BACK. THE LARGE ALUMINUM HEAT SINK LOCATED ON THE BOARD AND THE PART SCREWED TO IT WILL BE THE DEFECTIVE PART.
Dec 17, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I have gateway plasma tv srs bbc 50 " get verry hot in the exauste and in the sreen is it normal? think's
Yes,it's normal, a plasma uses a lot of power (over 300W) so it generates a lot of heat - especially the screen.Remember, plasma is an overheated gas so a large screen contains a very large amount of a very hot gas.
Jun 23, 2010 | Gateway GTW-P42M303 42 in. Plasma...
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Black stripe down TV plasma screen
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
May 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Hitachi big screen tv
if ths image is stuck on screen the solution should be white wash
Mar 01, 2009 | Hitachi 55HDS69 55 in. Plasma Television
No picture-Sony
did you ever get your tv repaired?
Apr 29, 2008 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Television and Sony Playstation
No, this is an urban legend unless you have a flat panel TV and are leaving it on games with fixed graphics. For example, leaving the GT2 game and playing it for 8 hours straight on a plasma may burn in the speedometer, etc... but honestly even next gen consoles have this type of graphics. If you have a Plasma or older LCD, just DONT have graphics sit still, period. Also, pixellation issues lend people to believe that the large squares are signs of burn in. They arent, just that if staying the same color for a long time they make for NASTIER burn-in. Hope this helps!
Jul 26, 2007 | Sony PlayStation® 2 Console
Panasonic TH-37PX60U 37 in. Plasma HDTV Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
