Horzontial black lines when there is a light colored background
The tv has a horzontial black line 6 to 8 inches from the top, a dark gray line mid screen, and a light gray line 6 to 8 inches from the bottom. They are only seen when there is a white or light colored background. The lines mid and bottom seem to quiver, almost like an old tv does when the horzontial hold is set incorrectly. Also the green hangs out to the right of any white item. I tried to set the convergance, but I only have blue h/v and red h/v adjustments
  • 1 more comment
  • l_garrison Jan 27, 2009
    when ther is a white item, green hangs out on the right side
    i have a repair manual, which board will the blanking capacitors be located in
    i am not satisfied with the last response. i just asked a simple question about which board the blanking capacitors would be in, as i said i have a repair manual, with all the boards listed, just need the name of the board.
    Sergeant:
  • 221 Answers
There r two convergence ic on the main board of the television as their number is 392---100 and u will have to replace both of them.then only it will get proper.
to get the exact part location and do it manually just click this link and follow the instructions
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
also for more help
You can try getting into it and if so, try adjusting the color, contrast, etc. once you enter.
You can find out how to enter by going to this site:
http://www.fixyourowntv.com/servicemenu.php
If that does not help, you may find the video processing and color separators, drivers or matrix is all messed up. This is usually a function of what is loosly called the "jungle chip". A big integrated circuit that manages all these things. The problem area could be within the chip itself or the hundreds of components that hang outside the chip. A tech will need to take measurements to find out the real problem area, in this case.
Posted on Jan 27, 2009
    Novelist:
  • 126 Answers
Sir the previous suggestion was also correct for u and what i suggest it that do not try any steps if u dont know about it the best thing is that go to the technician and get it replace....good luck
Posted on Jan 26, 2009
    Genius:
  • 1,011 Answers
Sir,
This is the convergence problem. Replace the Convergence IC's it solve the problem. U can do it yourself if u have knowledge in electronics. Or better contact technician.
  • Asfiya Ahamed
    Asfiya Ahamed Feb 01, 2009
    plz tell me your brand name and model no. of tv so i could easily find out some information.
    thanks
    Sergeant:
    Champion:
  • 435 Answers
Look for any capacitors burnt out.. These might be the blanking capacitors, which once damaged resulting in horizontal lines ...
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Why is the image going dark after a couple minutes?
Never repaired this model. It could be an inverter panel is weak. It may be the LCD strip that lights the panel is going bad. Thanks for asking. Matt of Martins TV Repair.
May 25, 2014 | Insignia Televison & Video
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Vertical lines in the picture on light background only
It sounds like you have Image burn in on your crt's. This happens when you watch programs in 4X3 mode. (The sides are blacked or grayed out and the picture is centered in the screen). The only way to fix this is to replace the crt's. I wish I had better news. Let me know if I can be of further assistance
Jan 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Horiantal line near top of screen
Suspect the Light Engine part # 939P977020.
Mar 08, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
