Question about egofly Lt-711 Hawkspy Helicopter Spy Camera
Common Issues with egofly Lt-711 Hawkspy 3.5ch Rc Large Helicopter Rtf With Gyro & Spy Camera
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
How long should charge the battery in my nano hercules helicopter
I re-categorized your post for you. It was posted in the MP3 player section. It should take approximately 20 minutes to charge, but it could take longer depending on the wall adapter and the cable you're using to charge it. Also, if you plug it into a computer it will take longer as it puts out less power.
Dec 26, 2015 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
My Gyro s107g helicopter won't connect to the remote. It just sits there not moving or any lights turning on.
It sounds like the two are not compatable. In other words the freakwinsy of the plane is not the same as the controller. THEY MUST MATCH. You may find the numbers on the back of the controller and where the batteries go in the chopper. If the numbers do not match, take it back to the store, and get one that does. Sorry for the spelling
Jan 13, 2015 | Syma S107G 3CH RC Helicopter RTF w/ Gyro...
Helicopter swerves right at speed
Hang it from a sting attached to the rotor shaft and see if it hangs level. It sounds to me like it is off balance.
Mar 07, 2014 | WL Toys WL V912 MAX 4CH FP RC Helicopter...
Just got a s301g Helicopter and it won't start up
Check the wiring where you plug in the charger to the helicopter. There is a red wire with quick disconnects. If its loose (the quick disconnect) you get this problem. In my case the helicopter came out of the box with this completely disconnected. It was hard to connect because there wasn't enough slack wire but once we did it the white light on the front of the helicopter came on and we were flying.
Nov 19, 2012 | Syma S301g Rc Helicopter 18" 3 Channel Rtf...
Hi my brother got a little helicopter and ind wont turn on or move
the batteries are most likely are in backwards or one is in wrong
Nov 21, 2010 | Worldtech Devices GYRO AirX 35CH Tilt...
Just bought the Walkera 38 Chinook. First flight I got an inch off the ground and landed it. Next attempt the top rotors spun initially then stops causing them to come in contact with the bottom ones. ...
Sorry for late reply, youve probably sorted this by now. This is common problen, some thing to do with the gyro. If you want to spin the rotors without takeing off the trick is to put full right turn then the gyro tries to compensate keeping the rotors turning at speed. To lift of the trick is to get airborn quickly without raising rotor speed slowly then the gyro will keep compensating and keep the rotors running. Had same problem myself, although saved the gears fortunately.
Hope this helps
Matt
Sep 02, 2010 | Walkera New 38 CH47 Chinook RTF 24GHz RC...
egofly Lt-711 Hawkspy Helicopter Spy Camera Logo
46 people viewed this question
Top egofly Video Cameras Experts
Are you an egofly Video Camera Expert? Answer questions, earn points and help others
