The remote control for this television got broken, so I bought an RCA Universal Remote Control (model RCU404). I did the code search automatically and manually, and the code was not found. I followed the instructions throughly, and nothing. Is there a code that can be used with Durabrand television or anything else that could help. Thank You.
I have found that on my Logitech 670 URC that the codes for my
Sylvania SST4323 will, unfortunately, also control the DURABRAD
WDT1905. I say unfortunately in that I am in a small nursing home room
and my roommate has the Durabrand and I have the Sylvania. Trying to
comtrol or respective TVs independently is a nightmare! Now that I
have "solved" the Durabrand code question, can someone please help me
get a divorce from my roommate's TV??? :-)
Use the codes 520, 115, 916, 027. i just used them for my durabrand 13 in tv. i actually used 520! it works with the phillips magnavox universal remote.
Use a directTV remote (we used rc32) with code 11034. Works fine for the unit we have, input and all! Enjoy!
Ring ASDA helpline 0845 3007775. I did and they gave me the Durabrand codes: 0584, 0065, 0634, 0742. I bought the 28" Widescreen TV and 0634 did it for me!!!! Good luck
If you did the manual search, the remote will not work with this TV set. You cannot simple add a code to your remote controller. When you do a search on a remote, what you are doing is checking every code that is pre-programmed into the remote at the factory. The only way you can add a code would be if you had what was called a learning remote. Those can be quite expensive. Good Luck
Can someone help me, i have the durabrand 13in and none of these codes are working for a RCA universal remote....please help
I purchased a 13 in. Durabrand color TV for my kitchen and wanted to program my Dish Network remote to control it. There were no codes listed in the Dish User Guide for Durabrand so I tried the Funai codes. They were 534, 541, 691, and 694. The 694 worked great for me and controls the TV on and off and sound very well. Good luck. Hope it works for you too.
Timrodlady
I have a Durabrand 13 color TV in my kitchen and was trying to program the Dish remote to control the TV. If the remote is an old one, try 032 or 132. Also try 11034. Durabrand seems to work with Funai Corp codes and sometimes Orion codes. I have an older Dish remote and finally found the code by doing the scan. When I checked the code to see what it is it is either 032 or 132. I cant tell if the first flash is fast (which would be a 0) or if not it would be a 1 but the other number are 32. Hope this helps.
Timrodlady
My family and I moved a few months ago and the movers misplaced our remote. We bought a universal remote but could not get it to work. There was two reasons to the problem. One, I couldn't get the right code and two, the TV has an automatic shut off when it hasn't been used for a while.
I cannot get my Sony multi use remote to work on this TV. I need the codes.
I have a duranbrand tv, I purchased a Phillips universal remote but cant find the code
looking for universal remote code for durabrand dwt1304 tv.
HAVE TRIED TWO DIFFERENT PROGRAMABLE REMOTE CONTROLS , BOTH RCA, ON MY DURABRAND BH1304D 13 INCH TV . SO FAR NO RESPON. FROM THE ENTERED CODES WHAT AM I DOING WRONG?
I have the same problem. I can not program a universal for my Durabrand tv. Please help
